#1 |
kranthiax: Importing an XPO through code
Источник: http://kranthiax.blogspot.com/2010/1...ough-code.html
============== This code helps to import an XPO using X++ static void importXPO(Args _args) { SysImportElements sysImportElements = new SysImportElements(); ; sysImportElements.newFile("C:\\Form_KranthiTest.xpo");/// this is your XPO filename sysImportElements.parmImportAot(true); sysImportElements.parmImportWithIds(false);///if you don't to import with IDvalues sysImportElements.import(); } Источник: http://kranthiax.blogspot.com/2010/1...ough-code.html
