#1 |
equalized: Dynamics ax take screenshots from FormControls
Источник: http://blog.equalized.be/2010/11/dyn...-formcontrols/
============== Hi all, Here is a little code snippet for you to take screen shots within a Dynamics Ax client. X++: public void run(FormControl _control) { str SaveToFileName; System.Drawing.Bitmap bitmap; System.Drawing.Graphics graphics; System.Windows.Forms.Screen primaryScreen; System.Drawing.Rectangle bounds; int x, y, k, l; System.Int32 width; System.Int32 height; #define.FileName('DynamicsAx_Screenshot.png') ; try { // 5 for the My Documents folder SaveToFileName = strfmt(@"%1\%2",WinApi::getFolderPath(5),#FileName); primaryScreen = System.Windows.Forms.Screen::get_PrimaryScreen(); bounds = primaryScreen.get_Bounds(); [x, y, k, l] = WinApi::getWindowRect(_control.hWnd()); width = _control.widthValue(); height = _control.heightValue(); // TwC: used API CLRObject // BP Deviation Documented bitmap = new System.Drawing.Bitmap(width,height); graphics = System.Drawing.Graphics::FromImage(bitmap); graphics.CopyFromScreen(x,y,0,0,bitmap.get_Size()); bitmap.Save(SaveToFileName, System.Drawing.Imaging.ImageFormat::get_Png()); } catch { error("The file could not be saved"); // TODO make label } } ![]() Источник: http://blog.equalized.be/2010/11/dyn...-formcontrols/
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. Last edited by Poleax; 22.04.2011 at 17:27. Reason: код |
Previous Thread
Next Thread
