Старый 01.04.2011, 13:11   #1
25,644 / 848 (80) +++++++
axStart: AIF tuning & testing
Источник: http://feedproxy.google.com/~r/axsta...PJkkQ/Blog.php
I have done a couple of AIF implementations. Some of them IIS related others BizTalk integration based.
They had a lot of common behavior. The speed of the framework was too slow. After analyzing all those runs, the next topics came along. With these changes AIF works up to 4 times faster.
AIF the framework
  • The Tables of AIF are not optimized for AOS caching  of data
  • The code for generation data for AIFruntimecache is programmed the wrong way.
  • The check to analyze the number of decimals is programmed inefficiently
  • The check to analyze time fields is programmed inefficiently
  • Missing indexes.
  • Data policies at runtimeo
  • Synchronizing the AOT
Look for more details at the next link www.axstart.com/AIF.php
This is a content summary only. Visit my website for full links, other content, and more!
Последний раз редактировалось Poleax; 01.04.2011 в 13:40.
За это сообщение автора поблагодарили: axstart (1).
axStart: InfoPath with default AIF file inbound offline Blog bot DAX Blogs 0 20.05.2008 19:05
axStart: InfoPath with default AIF web services Blog bot DAX Blogs 1 15.05.2008 02:27
axStart: Enrich AIF with the power of offline working (roadmap) Blog bot DAX Blogs 0 07.05.2008 15:05
axStart: How to use XSLT in AIF and what’s wrong with empty xml Nodes. Blog bot DAX Blogs 0 27.04.2008 18:07
axStart: What to do when AIF is not working and how to code: Blog bot DAX Blogs 0 23.12.2007 17:51
Часовой пояс GMT +3, время: 12:26.
