Старый 27.01.2011, 17:11   #1
kamalblogs: Dynamics Ax 2009 compatibilitywith .Net 4
Источник: http://kamalblogs.wordpress.com/2011...itywith-net-4/
I was recently developing a class library application for Dynamics Ax 2009  on Visual studio 2010. When I tried adding it  to the reference node, Ax threw an error informing that it is not a valid .Net assembly.  I had to change the version to 3.5 in the build properties of the VS Project to generate a compatible dll. I’m not sure if .Net 4 is compatible with Ax2009 but made it a note here….
Here is some compatibility information from SE Team  SE Team – Compatibility testing results but it only says Ax2009 and .Net 4 can run side by side. So guys it is good to check your .Net versions and try before you absorb it in to ax when facing a similar error.
Inside Dynamics AX 4.0: Working with the .NET Business Connector Blog bot DAX Blogs 0 04.10.2007 05:15
Часовой пояс GMT +3, время: 01:52.
