Старый 22.12.2010, 08:11   #1
Naresh: Read and Alter registry settings in Axapta
Источник: http://colorsofaxapta.spaces.live.co...172E!117.entry
Read and alter registry settings in Axapta
Here is a sample code of increasing max. open cursors during run-time. But, please note that its purpose is only to show you how to read and write registry. If you encounter any open cursors problem, it is recommended to optimize the SQL statement rather than changing the setting for maximum open cursors.
static void IncreaseMaxOpenCursors(Args _args)
    #winapi
    container   regRet;
    int         readReg;
    int         writeReg;
    str         keyValue, keyPath, configName;
    int         maxOpenCursors;
    //Specify your Axapta configuration utility name here
    configName = "LocalMachine";
    //New maximum open cursor, default is 90
    maxOpenCursors = 120;
    keyPath = @"SOFTWARE\Navision\Axapta\3.0\" + configName;
<div style="font-family:Verdana"><font color="#333399" size="2">    readReg  = WinAPI::regOpenKey( #HKEY_CURRENT_USER, keyPath, #KEY_READ);
    if (readReg)
        regRet = WinAPI::regGetValue(readReg, 'opencursors');
        keyValue = conpeek(regRet,1);
        info(keyValue);
        if (str2int(keyValue) <font color="#0000ff">
Microsoft Dynamics CRM Team Blog: Organizing Settings Navigation in CRM 4.0 Blog bot Dynamics CRM: Blogs 0 29.01.2009 02:20
Fred Shen: Read and alter registry settings in Axapta Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 12:27.
