Старый 21.12.2010, 04:13   #1
Solutions Monkey: Code compare utility in MorphX on EP User controls
Источник: http://blogs.msdn.com/b/solutions/ar...-controls.aspx
To enable the code compare utility in MorphX on EP user controls , edit the CodeIsSource method of SysTreeNode class in AOT and add UtilElmentType:WebControl and UtilElementType::WebSourceFile to the switch statement that returns true. After making the change, you shoudl be able to do code compare on user control markup and code behind files.
static boolean codeIsSource(UtilElementType _utilElementType)
boolean ret;
switch (_utilElementType)
case UtilElementType::WebPageDef :
case UtilElementType::WebStaticFile :
case UtilElementType::WebControl:
case UtilElementType::WebSourceFile:
ret = true;
return ret;
Solutions Monkey: 64bit machine - VS EP add-in not deploying user control to SharePoint while saving Blog bot DAX Blogs 0 06.01.2010 08:19
Solutions Monkey: AxPopup Controls in EP Blog bot DAX Blogs 0 22.09.2009 11:05
Solutions Monkey: Redirecting in EP user control to download a file Blog bot DAX Blogs 0 11.09.2009 15:05
epblog: Sharing Code between User Controls in EP Blog bot DAX Blogs 0 11.11.2008 08:05
Solutions Monkey: Using Microsoft Dynamics Ax 2009 Workflow controls in EP Blog bot DAX Blogs 0 30.07.2008 10:05
Часовой пояс GMT +3, время: 01:36.
