Старый 09.12.2010, 16:11   #1
emeadaxsupport: How to delete orphaned data remained from deleted company?
Источник: http://blogs.msdn.com/b/emeadaxsuppo...d-company.aspx
In AX 2009 it may happen that you delete a company but data related to this company remain in the database.
You can use this SQL script to delete this data:
DECLARE @_tableName nvarchar(40)
DECLARE @_companyId nvarchar(4)
SET @_companyId = -- replace with required company
DECLARE curSqlDictionary CURSOR FOR
SELECT A.SQLNAME
FROM SQLDICTIONARY A
INNER JOIN SQLDICTIONARY X ON X.TABLEID = A.TABLEID AND X.FIELDID = 61448
WHERE A.FIELDID = 0
AND A.FLAGS = 0
OPEN curSqlDictionary
FETCH NEXT FROM curSqlDictionary INTO @_tableName
WHILE @@FETCH_STATUS = 0
BEGIN
DECLARE @_sql nvarchar(4000)
SET @_sql = N'DELETE FROM ' + QUOTENAME(@_tableName) + N' WHERE DATAAREAID = @_dataAreaId'
EXEC sp_executesql @_sql, N'@_dataAreaId nvarchar(4)', @_dataAreaId = @_companyId
END
CLOSE curSqlDictionary
DEALLOCATE curSqlDictionary
--author:Martin Falta--editor:Daniel Durrer--date:09/Dec/2010
Pawan's Ax blog: How To Delete All Transaction Data In Ax Blog bot DAX Blogs 4 15.06.2010 11:23
emeadaxsupport: Long running process switches from one company to another company Blog bot DAX Blogs 0 27.01.2010 20:05
emeadaxsupport: Query execution failed for data set 'Company' Blog bot DAX Blogs 0 28.10.2009 00:06
Microsoft Dynamics CRM Team Blog: Data Migration Manager Tips and Tricks Blog bot Dynamics CRM: Blogs 0 02.09.2008 22:05
How do I delete a datasource from a query ? (by stelsig) Maxim Gorbunov DAX in English 0 22.03.2006 12:21
Часовой пояс GMT +3, время: 20:09.
