Старый 14.07.2010, 19:05   #1
paruvella: AIF – Outbound with a number of Records per XML
Источник: http://paruvella.spaces.live.com/Blo...4DB0!545.entry
Again I am back with some AIF stuff.
Assume that if we have a requirement like, we need to send at least 10 records per XML as an outbound.
Have a look on the following example which gives an idea, how we can send 10 or some number of records in an XML as an outbound.
static void AIFSendChAccForRangeRec(Args _args)
    AxdSendContext                      axdSendContext = AxdSendContext::construct();
    AifConstraint                       aifConstraint = new AifConstraint() ;
    AifConstraintList                   aifConstraintList = new AifConstraintList();
    AifActionId                         actionId;
    AifEndpointList                     endpointList;
    Query                               query;
    QueryBuildDataSource                queryBuildDataSource;
    QueryBuildRange                     qbr;
    RecId                               start;
    RecId                               end;
    LedgerTable                         ledgerTable;
    //reading lowest recordId for a specific criteria
    select firstonly RecId from ledgerTable where ledgerTable.AccountPlType == LedgerAccountType::Heading;
    start = ledgerTable.RecId;
    end = start + 100;          // add some value to the recordId. This increment value we can change depends on req.
    query = new Query(queryStr(AxdChartOfAccounts));
    AxdSend::removeChildDs(query);
    queryBuildDataSource = query.dataSourceTable(tablenum(LedgerTable));
    queryBuildDataSource.addRange(fieldnum(LedgerTable, AccountPlType)).value(QueryValue(LedgerAccountType::Heading));
    qbr = queryBuildDataSource.addRange(fieldnum(LedgerTable, RecId));
    //here adding the records range condition, to filter the no.of records to send in XML
    qbr.value(strfmt('( (%1 >= %2) && (%1 <= %3) )',
                       fieldstr(LedgerTable, RecId),
                       start,
                       end));
    actionId = AifSendService::getDefaultSendAction(classnum(LedgerChartOfAccountsService), AifSendActionType::SendByQuery);
    aifConstraint.parmType(AifConstraintType::NoConstraint);
    aifConstraintList.addConstraint(aifConstraint);
    endpointList = AifSendService::getEligibleEndpoints(actionId, aifConstraintList);
    //implemented the AIF-Outbound using query object
    AifSendService::submitFromQuery(actionId, endpointList, query, AifSendMode::Async);
paruvella: Generation of XML file from DAX, without using AIF Blog bot DAX Blogs 0 23.04.2010 12:05
Dave: AIF Configuration and Additional Findings Blog bot DAX Blogs 1 04.11.2009 17:29
axStart: How to use XSLT in AIF and what’s wrong with empty xml Nodes. Blog bot DAX Blogs 0 27.04.2008 18:07
Dianne Siebold: Limit Outbound Documents in 4.0 (AIF) Blog bot DAX Blogs 0 12.01.2008 00:23
Pokluda: Outbound web service (AIF) Blog bot DAX Blogs 0 28.10.2006 17:43
Часовой пояс GMT +3, время: 02:25.
