Старый 24.05.2010, 15:05   #1
saveenr: Dynamics AX 2009: Integrating AX with Powershell
Источник: http://blogs.msdn.com/saveenr/archiv...owershell.aspx
[UPDATE on 2010-05-15]
To documentation for this powershell module has been placed here: http://cid-19ec39cb500669d8.skydrive...owershell.docx
if you read this blog, you know I love command line interfaces – so this shouldn’t be a surprise. If you look at the Dynamics AX BI CodePlex project, you’ll see a Visual Studio 2008 project called “DynamicsAXPS”.
This is a Powershell 2.0 module that lets you start exploring and controlling AX from the command line. In this post I’ll demonstrate how to use it.
First, install Powershell 2.0 and start it. This module assumes you already have the AX Client installed on the machine and configured to connect to an AX Server.
LOADING THE MODULE
Once you build the project you’ll see these DLLs in the bin/debug directory… The module itself is the file called “DynamicsAXPS.dll”
Now load it via this command
Import-Module .\DynamicsAXPS.dll
The warnings are because I have some non-standard cmdlet verbs defined.
FINDING AX CMDLETS
Get-Command -Module DynamicsAXPS
INTERROGATING THE AOT
Let’s get a node in the AOT – I’ll choose the CustTable
$custtable = Get-AXNode "\Data Dictionary\Tables\CustTable"
$custtable | Get-Member
Of course we can pipe this to Out-GridView …
$custtable | Get-Member | Out-GridView
What about the child nodes under CustTable? Use Get-AXNodeChildItem
Get-AXNodeChildItem "\Data Dictionary\Tables\CustTable"
What if we wanted all the nodes underneath CustTable recursively? Just add the –Recurse flag. As you can see there are a lot of nodes
Get-AXNodeChildItem "\Data Dictionary\Tables\CustTable" -Recurse
Use Get-AXNodeProperties to get info about the properties for a specific node.
Get-AXNodeProperties "\Data Dictionary\Tables\CustTable"
LABELS
If you need to get the value for a label us Get-AXLabel
Get-AXLabel SYS11307
You can ask for multiple labels at the same time
Get-AXLabel SYS11307,SYS125115
Getting MetaData for Tables, Enums, and EDTs
There are three commands available.
One for Extended Data Types.
Get-AXEDTMetaData ABCModelType
One for Enums:
Get-AXEnumMetaData ABCModel
One for Tables
Get-AXTableMetaData CustTable
If you are curious about the metadata, you can retrieve it from the metadata objects that are returns
Here’s how to find out about the fields.
$md = Get-AXTableMetaData CustTable
$md.Fields | Out-GridView
OK, that’s a lot of fields, we can filter it down
$md.Fields | select Name,DataType,FieldType,DisplayLength  | Out-GridView
GETTING DATA FROM A TABLE
$datatable = Get-AXTableData -Table CustTable -Fields *
$datatable.Rows | Out-GridView
$datatable = Get-AXTableData -Table CustTable -Fields AccountNum,Name,Phone
CREATE A TABLE VIA AN XPO
Create-XPOForTable -Name Foo -Filename "D:\\Create_Table_Foo.xpo" -Fields A,B,C –FieldTypes INT,STRING,REAL
This creates a simple XPO file that will create that table.
Just import the XPO like any other and your table is ready
ADD RECORDS TO A TABLE
Add-AXRecord -Table Foo -Fields A,B,C  -Values (1,"FOO",3.3)
Add-AXRecord -Table Foo -Fields A,B,C  -Values (2,"Bar",7.1)
And if you open the table in AX …
You’ll see the data has been placed in the table
powershell, полезное
JOPX: Dynamics AX 2009 - Enterprise Portal link bonanza Blog bot DAX Blogs 0 27.11.2008 01:05
Часовой пояс GMT +3, время: 08:42.
