Старый 17.05.2010, 13:05   #1
CRM DE LA CREME! Enabled and disable fields based on a user role
Источник: http://crmdelacreme.blogspot.com/201...-based-on.html
All had a question to see if this could be done and this is the code that was used to enabled and disable fields based on a user role when a value is changed in a list box change event.
function UserHasRole(roleName)
//get Current User Roles, oXml is an object
var oXml = GetCurrentUserRoles();
if(oXml != null)
//select the node text
var roles = oXml.selectNodes("//BusinessEntity/q1:name");
if(roles != null)
for( i = 0; i < roles.length; i++)
if(roles[i].text == roleName)
//return true if user has this role
return true;
//otherwise return false
return false;
function GetCurrentUserRoles()
var xml = "" +
GenerateAuthenticationHeader() +
" role" +
" name" +
" false" +
" roleid" +
" role" +
" systemuserroles" +
" roleid" +
" Inner" +
" systemuserid" +
" systemuser" +
" systemuserid" +
" Inner" +
" And" +
" systemuserid" +
" EqualUserId" +
var xmlHttpRequest = new ActiveXObject("Msxml2.XMLHTTP");
xmlHttpRequest.Open("POST", "/mscrmservices/2007/CrmService.asmx", false);
xmlHttpRequest.setRequestHeader("SOAPAction"," http://schemas.microsoft.com/crm/2007/WebServices/RetrieveMultiple");
xmlHttpRequest.setRequestHeader("Content-Type", "text/xml; charset=utf-8");
xmlHttpRequest.setRequestHeader("Content-Length", xml.length);
xmlHttpRequest.send(xml);
var resultXml = xmlHttpRequest.responseXML;
return(resultXml);
//This is the code used to enable or disable the fields in CRM 4.
try
if(crmForm.all.isp_goodwill.DataValue == '1') //List box selected = yes
if(UserHasRole("Goodwill Manager")) //Role to look for
//Fields to enable.
crmForm.all.isp_goodwillrequestedbyid.Disabled = false;
crmForm.all.isp_goodwillapprovedbyid.Disabled = false;
crmForm.all.isp_goodwillvalueapproved.Disabled = false;
catch(e)
alert(this.gErrorMessage("Authorisation Form",e.description ));
CRM DE LA CREME! Some useful CRMform jscripts Blog bot Dynamics CRM: Blogs 0 02.09.2009 10:05
Microsoft Dynamics CRM Team Blog: Troubleshooting the Microsoft Dynamics CRM Client for Outlook Blog bot Dynamics CRM: Blogs 0 30.05.2009 12:05
Microsoft Dynamics CRM Team Blog: Implementing Approval Verification Processes Blog bot Dynamics CRM: Blogs 0 12.01.2009 20:05
Microsoft Dynamics CRM Team Blog: Data Migration Manager Tips and Tricks Blog bot Dynamics CRM: Blogs 0 02.09.2008 22:05
Часовой пояс GMT +3, время: 07:53.
