#1 |
kamalblogs: Vertical Selection in X++ Editor in Dynamics Ax
Источник: http://kamalblogs.wordpress.com/2010...n-dynamics-ax/
============== Generally in use X++ editor we use line selection or complete block selection to modify the text. In Ax you can also use vertical block selection to remove spaces or delete text. Here is a small demonstration of vertical block selection along with the way to do it. ![]() Источник: http://kamalblogs.wordpress.com/2010...n-dynamics-ax/
| За это сообщение автора поблагодарили: casperkamal (1). | |
