Старый 03.04.2010, 05:15   #1
emeadaxsupport: Error “Not enough rights” when you select Category in Electronic Time Card
Источник: http://blogs.msdn.com/emeadaxsupport...time-card.aspx
Some time ago we found this problem when you do not have Project license key and you try to access the Electronic Time Card in Enterprise Portal. While  you click on the drop down of ''Category'' field to select values it throws an error
Not enough rights
Problem can be fixed in very wasy way: do not show field category to end user: Go to AOT \ Web \ Web files \ Web controls \ JmgEPJobRegistration and double click on it the edit window will apeare Look for line:
and replace it with
To apply changes you need to run AxUpdatePortal: http://msdn.microsoft.com/en-us/library/dd261467.aspx
mscrm4ever: CRM 4.0 Supported Multi Select (Picklist) Control Blog bot Dynamics CRM: Blogs 0 25.12.2008 15:05
Dianne Siebold: Import Credit Card Transactions for Expense Mgmt Blog bot DAX Blogs 0 19.12.2008 10:05
Разница NotInTTS и Found Logger DAX: База знаний и проекты 6 18.09.2008 12:35
Часовой пояс GMT +3, время: 02:09.
