Старый 28.01.2010, 15:05   #1
palleagermark: Important limitation in Enterprise Portal deployment
Источник: http://palleagermark.blogspot.com/20...nterprise.html
You cannot out of the box run multiple EP sites, with different versions of User Control code, on the same IIS.
This is because SharePoint expects the code to be under the %System drive%:\Program Files\Common Files\Microsoft Shared\web server extensions\12\TEMPLATE\LAYOUTS\ep folder and you cannot deploy to different folders.
A workaround where you map the layout file differently for each site, is described in KB944105. But it has some conequences, which you can read more about in the knowledgebase article.
I have not tested if the workaround actually works with AX, and would love to hear from someone who may have tried this out.
epblog: Microsoft Dynamics AX Enterprise Portal Development and Deployment Webinars Blog bot DAX Blogs 0 23.04.2009 16:05
Solutions Monkey: Convergence session: Enterprise Portal Deployment Tips and tricks Blog bot DAX Blogs 0 26.03.2009 08:05
Solutions Monkey: Microsoft Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks – 3 Blog bot DAX Blogs 0 27.10.2008 08:05
Solutions Monkey: Microsofty Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks - 2 Blog bot DAX Blogs 0 30.09.2008 07:07
Solutions Monkey: Microsofty Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks - 1 Blog bot DAX Blogs 0 26.06.2008 09:05
Часовой пояс GMT +3, время: 07:52.
