Старый 22.01.2010, 05:10   #1
Dianne Siebold: “Request Failed” Error in AIF
Источник: http://blogs.msdn.com/dsiebold/archi...or-in-aif.aspx
One of the SDETs on our team recently made me aware of a somewhat unintuitive error message that you might receive when sending a message to your AX installation using AIF. In the inbound XML message, the elements must be in alphabetical order. If they are not in the correct order, you may see a message that looks something like this real-world example:
The request failed with the following error: The element 'SalesTable' in namespace 'http://schemas.microsoft.com/dynamics/2008/01/documents/SalesOrder' has invalid child element 'LanguageId' in namespace 'http://schemas.microsoft.com/dynamics/2008/01/documents/SalesOrder'.
List of possible elements expected: 'QuotationId, ReceiptDateConfirmed, ReceiptDateRequested, RecId, RecVersion, Reservation, ReturnDeadline, ReturnItemNum, ReturnReasonCodeId, ReturnReplacementCreated, ReturnReplacementId, ReturnStatus, SalesGroup, SalesId, SalesName, SalesOriginId, SalesPoolId, SalesResponsible, SalesStatus, SalesTaker, SalesType, SalesUnitId, SettleVoucher, ShipCarrierAccount, ShipCarrierAccountCode, ShipCarrierBlindShipment, ShipCarrierDeliveryContact, ShipCarrierDlvType, ShipCarrierExpeditedShipment, ShipCarrierFuelSurcharge, ShipCarrierID, ShipCarrierResidential, ShippingDateConfirmed, ShippingDateRequested, smmCampaignId, smmSalesAmountTotal, StatProcId, TaxGroup, totalBalance, TotalCashDiscount, TotalInvoice, TotalMiscCharges, TotalSalesTax, TransactionCode, Transport, URL, VATNum, SalesLine, DocuRefHeader, MarkupTransHeader' in namespace 'http://schemas.microsoft.com/dynamics/2008/01/documents/SalesOrder'
As you can see, the error message doesn’t exactly come out and say “Hey, your XML elements aren’t in alphabetical order.” It more hints around about it.
This error is returned when the inbound message is validated. So if you encounter this error, you’ll want to start troubleshooting by checking the source XML and the order of the elements.
For more information about document schemas in AIF on MSDN, click here.
Dianne Siebold: Getting Error Details in AIF Blog bot DAX Blogs 0 01.04.2009 05:07
Dianne Siebold: Video About the AIF Services and WCF Blog bot DAX Blogs 0 11.10.2008 07:43
Dianne Siebold: AIF Queries & Schemas: A Picture is Worth a Thousand Words Blog bot DAX Blogs 0 12.09.2008 02:05
Dianne Siebold: AIF Top Ten Blog bot DAX Blogs 1 22.04.2008 11:19
Dianne Siebold: Limit Outbound Documents in 4.0 (AIF) Blog bot DAX Blogs 0 12.01.2008 00:23
Часовой пояс GMT +3, время: 00:54.
