#1 |
hariprasadp: Import Excel file data in to dynamics AX through Dynamics AX
Источник: http://hariprasadp.spaces.live.com/B...B91F!208.entry
============== X++: //--HariPattela--Dynamics AX import table data form Excel to AX table static void ExcelFile_Import(Args _args) { int i; //Excel related declarations #excel SysExcelApplication SysExcelApplication; SysExcelWorksheet SysExcelWorksheet; SysExcelWorksheets SysExcelWorksheets; SysExcelWorkbooks SysExcelWorkbooks; SysExcelWorkbook SysExcelWorkbook; SysExcelRange SysExcelRange; SysExcelCell SysExcelCell; SysExcelCells SysExcelCells; SysExcelRange range; COMVariant file; //progress bar #avifiles SysOperationProgress simpleProgress; //variables used while importing data int j, imported, noofrows, firstrow; real ratio; str strExample; int intExample; ; //check if file has been selected //open the selected excel try{ sysExcelApplication = SysExcelApplication::construct(); sysExcelApplication.visible(false); sysExcelWorkbooks = sysExcelApplication.workbooks(); file = new COMVariant(); file.bStr('C:/fg.xls'); sysExcelWorkbook = sysExcelWorkbooks.add(file); SysExcelWorksheets = sysExcelWorkbook.worksheets(); SysExcelWorksheet = SysExcelWorksheets.itemFromNum(1); } catch(Exception::Error) { throw error("cannot open the excel file"); } try { SysExcelRange = SysExcelWorksheet.cells().range(#ExcelDataRange); //Get the number of rows in excel file range = SysExcelRange.find("*", null, #xlFormulas, #xlWhole, #xlByRows, #xlPrevious); if(range) { noofrows = range.row(); } else { sysExcelApplication.workbooks().close(); sysExcelApplication.quit(); throw error('fg.xls'); } //Get the number of columns in excel file range = SysExcelRange.find("*", null, #xlFormulas, #xlWhole, #xlByColumns, #xlPrevious); if(range) { sysExcelApplication.workbooks().close(); sysExcelApplication.quit(); throw error('C:/fg.xls'); } } catch(Exception::Error) { sysExcelApplication.workbooks().close(); sysExcelApplication.quit(); throw error("Hata!"); } sysExcelCells = sysExcelWorksheet.cells(); //initialize the progress bar ratio = noofrows / 100; simpleProgress = SysOperationProgress::newGeneral(#aviUpdate, 'file is importing', 100); //importing part //Chck currency ttsbegin; //read rows of excel for(j=3; j<=noofrows; j++) { imported++; print(imported); strExample = sysExcelCells.item(j, 1).value().bStr(); intExample = sysExcelCells.item(j, 4).value().double(); } pause; ttscommit; //display info info(int2str(imported) + " records imported."); //close the excel file sysExcelApplication.workbooks().close(); sysExcelApplication.quit(); }
| За это сообщение автора поблагодарили: Gustav (0). | |
