Старый 26.08.2009, 16:55   #1
loka is offline
loka
Вопрос по установке
Решил на домашнем компе развернуть Ax09
по WinServer2003 и SQL 2008
получаю ошибку и такой вот лог при установке AOS:
=== Setup logging started: 26.08.2009 16:32:54 ===
Running file: "C:\DOCUME~1\SERVER~1.000\LOCALS~1\Temp\AxSetup\AxSetup.exe" RelatedFilesDir="E:\cl\Общее\Дистрибутивы\ax09\DynamicsAX2009"
AxSetup version number: 5.0.593.0
Microsoft Windows NT 5.2.3790 Service Pack 2 (32 bit)
SERVERC
cl\Администратор
Interactive: True
RelatedFilesDir=E:\cl\Общее\Дистрибутивы\ax09\DynamicsAX2009
Property RelatedFilesDir set to: 'E:\cl\Общее\Дистрибутивы\ax09\DynamicsAX2009\'
Property SetupLanguage set to: 'RU'
=== Loading parameters from the command line or a parameter file ===
Initializing log file: C:\Documents and Settings\All Users\Application Data\Microsoft\Dynamics AX\Dynamics AX Setup Logs\2009-08-26 16-32-54\DynamicsSetupLog.txt
=== Starting evaluation of existing installation state ===
MSI file: Components32.msi Installed: False
MSI file: ClientHelp.msi Installed: False
=== Checking parameters ===
Property InstallPath set to: 'C:\Program Files\Microsoft Dynamics AX\50'
=== Starting UI phase ===
Property AcceptLicenseTerms set to: '1'
Property BypassWarnings set to: '0'
Property RunMode set to: 'Custom'
Property InstallAos set to: '1'
Property ClientAosServer set to: 'SERVERC'
Property BypassWarnings set to: '1'
Property DbServerType set to: '0'
Performing prerequisite validation: VC++ SP1
Performing prerequisite validation: SNAC
Property DbSqlServer set to: 'SERVERC'
Connected to SQL Server: 'SERVERC'
Property DbSqlDatabaseName set to: 'cl09'
Property InstallApplication set to: '1'
Property ApplicationInstanceName set to: 'cl09'
Property ApplicationRegion set to: '-'
Property AosPort set to: '2713'
Property AosInstanceName set to: 'cl09'
Property AosReportErrors set to: '0'
Exception: System.BadImageFormatException
Message: Could not load file or assembly 'Microsoft.Dynamics.Framework.Deployment.Web, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The module was expected to contain an assembly manifest.
FullText: System.BadImageFormatException: Could not load file or assembly 'Microsoft.Dynamics.Framework.Deployment.Web, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The module was expected to contain an assembly manifest.
File name: 'Microsoft.Dynamics.Framework.Deployment.Web, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'
at Microsoft.Dynamics.Setup.DeploymentWebWrapper.GetLocalizedNtAuthorityNetworkServiceName()
at Microsoft.Dynamics.Setup.MainForm.s210_ShowTab(Object sender, EventArgs e)
at Microsoft.Dynamics.Setup.AxTabPage.ShowPage()
at Microsoft.Dynamics.Setup.MainForm.ShowPage(PageIDs pageID)
at Microsoft.Dynamics.Setup.MainForm.mainFormButtonNext_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
==== Setup encountered an unhandled exception and could not be completed. For details see the previous messages in the log. ===
Помогите расшифровать пожалуйста.
Последний раз редактировалось loka; 26.08.2009 в 17:01.
ax2009, установка
Ошибка в логе при установке клиента AX 2009 sao DAX: Администрирование 9 04.02.2010 11:56
Вопрос: учет затрат по закупкам в модуле Проекты Keks DAX: Функционал 5 13.07.2006 10:15
Часовой пояс GMT +3, время: 01:39.
