Старый 18.08.2009, 11:05   #1
CRM DE LA CREME! Hiding Button's on related views in CRM
Источник: http://crmdelacreme.blogspot.com/200...ws-in-crm.html
Onload:
HideAssociatedViewButtons = function(loadAreaId, buttonTitles)
var navElement = document.getElementById('nav_' + loadAreaId);
if (navElement != null)
navElement.onclick = function LoadAreaOverride()
// Call the original CRM method to launch the navigation link and create area iFrame
loadArea(loadAreaId);
HideViewButtons(document.getElementById(loadAreaId + 'Frame'), buttonTitles);
/* Used internally by the 'HideAssociatedViewButtons' method */
HideViewButtons = function(Iframe, buttonTitles)
if (Iframe != null)
Iframe.onreadystatechange = function HideTitledButtons()
if (Iframe.readyState == 'complete')
var iFrame = frames[window.event.srcElement.id];
var liElements = iFrame.document.getElementsByTagName('li');
for (var j = 0; j < buttonTitles.length; j++)
buttonTitleParts = buttonTitles[j].split('::');
if (buttonTitleParts.length > 0)
buttonTitle = buttonTitleParts[0];
for (var i = 0; i < liElements.length; i++)
liElement = liElements[i];
if (liElement.getAttribute('title') == buttonTitle)
if (buttonTitleParts.length == 1)
liElement.style.display = 'none';
break;
else
/* We want to hide a menu item in a drop-down menu.
Find the descendant text element with the specified text.
Then find its parent list item and hide it:
menuText = buttonTitleParts[1];
var spanElements = liElement.getElementsByTagName('span');
for (var k = 0; k < spanElements.length; k++)
spanElement = spanElements[k];
if (spanElement.className == 'ms-crm-MenuItem-Text' )
textElement = spanElement.firstChild;
if (textElement != null && textElement.nodeType == 3) /* 3 = Node.TEXT_NODE */
if (textElement.data == menuText)
liMenuItemElement
= spanElement.parentNode.parentNode.parentNode;
liMenuItemElement.style.display = 'none';
break;
HideAssociatedViewButtons("CRMRELATIONSHIP", ["Add existing XXXXto this record", "Add a new XXXX to this record"]);
CRM DE LA CREME! Microsoft CRM 4.0 Update Rollup Best Practices Blog bot Dynamics CRM: Blogs 0 18.08.2009 11:05
CRM DE LA CREME! Three Top Tips for CRM 4.0 Plugin Development Blog bot Dynamics CRM: Blogs 0 13.08.2009 15:05
CRM DE LA CREME! Installing CRM 3.0 in a SQL instance Blog bot Dynamics CRM: Blogs 0 13.08.2009 15:05
Часовой пояс GMT +3, время: 04:48.
