Старый 11.08.2009, 18:08   #1
Poleax is offline
Poleax
Аватар для Poleax
1,353 / 595 (22) +++++++
Записей в блоге: 34
? Hotfix Rollup 2 (RU2) for Microsoft Dynamics AX 2009
Кто пробовал устанавливать Hotfix rollup 971536 is available for Microsoft Dynamics AX 2009 Service Pack 1 (5.0.1500.809)?
Какие ощущения?
Там добавлено для Russian Federation
Russian Federation
Inventory list of non-material goods (Inv-1a)
According to Russian law, an intangible assets (IA) inventory check must be performed one time each year for the company. The "IA Counting list (Unified form INV-1a)" statutory document is used for IA inventory control. This update enables you to create a separate "IA Counting list (INV-1a)" inventory form for these types of assets. Moreover, the "IA Counting list" report contains information about quantity and costs of the intangible assets for the specified inventory date.
Quality deviations and quantity deviations when you receive inventory holdings (TORG-2) law
The "Receipt list for goods with quality and quantity deviation TORG-2" form is used to reflect quantity deviations and quality deviations in a vendor's document for goods. When deviations occur, the form is created for the additional claims to the vendor.
Quality deviations and quantity deviations when you receive import material goods (TORG-3) law
The "Receipt list for foreign goods with quality and quantity deviation TORG-3" form is used to reflect quantity deviations and quality deviations in a vendor's document for foreign goods. When deviations occur, the form is created for the additional claims to the vendor.
Goods report (TORG-29)
The Goods report (TORG-29) is mandatory for trade, and displays information about goods movement. This report also reveals deviations between actual quantity on-hand and quantity in receipt, and issues inventory documents for the reporting period.
To run this report, click Inventory management, click Reports, click Transactions, and then click Trade report.
Importing and supporting reference book of banks
According to Provision No. 225-П that is dated May 6, 2003, the bank identification code (BIC) dictionary is supported by the authorizing department, the Russian Federation Central Bank (RF CB). This dictionary is changed two times each week and is available on the RF CB site. The Import process automatically synchronizes this dictionary data with the dictionary data in Microsoft Dynamics AX.
By importing the dictionary data from the RF CB site, you can synchronize concurrently bank characteristics for clients, customers, and your company. You can select to perform the Import process for certain regions or banks. You can perform the Import process by using the following actions:
• Add
• Update
• Add and update
At the end of the Import process, you can view the result set in the information log.
Reporting update according to new tax depreciation method
A new method of depreciation amount calculation for applying the nonlinear depreciation method of accruals is introduced by the "N 158-ФЗ" Federal law that is dated July 22, 2008. This update enables you to perform the following processes:
• Create the "FA depreciation" tax register and the "IA depreciation" tax register by using depreciation groups for fixed assets. This nonlinear tax method is used for the depreciation process.
• Display total lines for each group in both registers.
• Print fixed assets reports in the FA module by using a depreciation group.
Depreciation bonus recovery
If a fixed asset is sold before five years from the date of purchase, the depreciation bonus is restored, and then the tax register is created. The "Depreciation bonus recovery" register contains information about the fixed asset and depreciation bonus amount. This register is a child register of the following registers:
• Calculation of constant tax differences
• Incomes - current period
Tax differences for advance payments calculations in tax accounting
According to changes in Russian law, the exchange adjustment on advances on the date of the settlement was removed from business accounting practices from January 1, 2008. Therefore, the CTL amount and the CTA amount in exchange adjustments are now calculated.
Hot Fixes Released For Microsoft Dynamics AX 2009
Hotfix Rollup 2 (RU2) AX 2009 Rollups KB 971535 5.0.593.662
Hotfix Rollup 2 (RU2) AX 2009 Service Pack 1 Rollups KB 971536 5.0.1500.809
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 2009 Roll-up 2 is available on Partner Source and Customer Source!
Когда будут локализованные demo данные и VPC Ax 2009 SP1 EE ?
Последний раз редактировалось Poleax; 11.08.2009 в 18:13.
Старый 11.08.2009, 19:31   #2
zhan is offline
zhan
По поводу HotFix ни чего сказать не могу, пока не ставили...
Демо данные опубликованы на www.mbspartners.ru, в разделе Материалы по версиям AX > ProductUpdatesTemp.
Если у Вас есть доступ, то можно их оттуда скачать.
Есть ли они на Сustomersource? Я не знаю...
Демо данные поставляются в следующем виде:
Отдельно поставляется база для модуля Зарплата и отдельно – для всех остальных модулей - Финансы, Налоговый учет и Основные средства.
Каждая база представлена в трех статусах:
· Настройки
· Настройки и операции
· Настройки, операции и проводки
Каталог с зарплатными базами
Каталог с основными базами
За это сообщение автора поблагодарили: Poleax (1).
Старый 12.08.2009, 21:32   #3
пожалуйста, дальнейшее обсуждение в новостях
AX 2009: в России!
Старый 02.09.2009, 18:55   #4
AlGol is offline
AlGol
277 / 93 (4) ++++
Angry
Сообщение от zhan Посмотреть сообщение
Народ, а кто нибудь пробовал эти данные закачать в систему?
Долго пытался понять на какую версию их нужно натягивать, наконец-то сообщили что это должна быть Ax2009 SP1 Rollup2.
Но и в нее как-то не лезет
Старый 02.09.2009, 22:15   #5
sukhanchik is offline
sukhanchik
Аватар для sukhanchik
3,348 / 3564 (125) ++++++++++
да вот мне кстати тоже интересно - к примеру зарплата явно не адаптирована к Rollup2. Ее как - не ставить?
Старый 03.09.2009, 11:06   #6
Poleax is offline
Poleax
Аватар для Poleax
Записей в блоге: 34
установился Hotfix Rollup 2 (RU2) AX 2009 Service Pack 1 Rollups KB 971536 5.0.1500.809 нормально, но при работе вылезли проблемки в виде Объект CLR не может быть упакован в любой тип Microsoft Dynamics. Возможно появятся и другие.
Во второй половине сентября 2009 обещают выпустить Roll-up 3 for AX2009 RTM and SP1 Можно подождать, может что и поправят еще.
Старый 04.09.2009, 11:55   #7
AlGol is offline
AlGol
277 / 93 (4) ++++
Вот интересный вопрос.
Выложенные демо-базы явно содержат данные по зарплате. Т.е. когда их делали у человека стоял rollup и была функциональность зарплаты.
Но насколько я увидел - стыковка опубликованной зарплаты с Rollup2 возможна только вручную. Т.е. оперированием в средствах разработки.
Старый 04.09.2009, 12:11   #8
sukhanchik
Сообщение от AlGol Посмотреть сообщение
Т.е. по-русски говоря, демо-данные ориентированы на зарплату, адаптированную к Rollup2, которая еще официально не опубликована. А под оперированием в средствах разработки означает самостоятельный подъем зарплаты на Rollup2.
Ясно. Спасибо
Старый 28.09.2009, 15:05   #9
rus_stas is offline
rus_stas
Сообщение от Poleax Посмотреть сообщение
Опубликован AX 2009 SP1 Rollup 3 (5.0.1500.1313).
Уже опубликован AX 2009 SP1 Rollup 3.
rus_stas
ax2009, demo, hotfix
Hotfix rollup 967145 is available for Microsoft Dynamics AX 2009 Service Pack 1 Dima_Dima DAX: Программирование 7 08.05.2009 11:29
JOPX: Dynamics AX 2009 - Enterprise Portal link bonanza Blog bot DAX Blogs 0 27.11.2008 01:05
Часовой пояс GMT +3, время: 14:21.
