Старый 27.05.2009, 09:05   #1
axaptapedia: Registry client name
Источник: http://www.axaptapedia.com/Registry_client_name
Summary: New page: Having been handed a requirement to connect machines which log onto Axapta 3.0 from Terminal Services and utilize the local Windows XP client hostname, I've found the Windows Registry can ...
Having been handed a requirement to connect machines which log onto Axapta 3.0 from Terminal Services and utilize the local Windows XP client hostname, I've found the Windows Registry can provide one possible solution.
str getRegistryClientName()
    // Get hostname from Terminal Services Session
    #winAPI
    int intHandle;
    container clintName;
    intHandle = WinAPI::regOpenKey(#HKEY_CURRENT_USER, 'Volatile Environment', #KEY_READ);
    clintName = WinAPI::regGetValue(intHandle, 'CLIENTNAME');
    WinAPI::regCloseKey(intHandle);
    return conpeek(clintName,1);
Further into the process you might need to check the value is not of the form CONSOLE, as this would pertain to a locally logged in session, which differs in the Registry Key value. For this I found the winAPI::getComputerName() method was more reasonable.
void getHostName()
    if(hostName)
        return;
    // assume TS session
    hostName = this.getRegistryClientName();
    if(STRUPR(hostName) == "CONSOLE")// local
         hostName = winAPI::getComputerName();
Of course within the Class Declaration it would be a good idea to include the following string!
str hostName;
Jim Wang: Get Entity/Attribute's Display Name from CRM database Blog bot Dynamics CRM: Blogs 0 28.03.2009 01:05
axcoder: PowerShell + Ax Blog bot DAX Blogs 1 09.01.2009 18:05
axaptapedia: Create New AOT Project From Template Blog bot DAX Blogs 0 29.08.2008 21:10
axaptapedia: Change table owner Blog bot DAX Blogs 1 22.03.2007 20:56
axaptapedia: Control AOS from command line Blog bot DAX Blogs 0 09.03.2007 14:50
Часовой пояс GMT +3, время: 15:19.
