Старый 02.04.2009, 09:05   #1
Solutions Monkey: How to use Chart Control in EP 2009?
Источник: http://blogs.msdn.com/solutions/arch...n-ep-2009.aspx
ASP.NET Chart Control
(1) Install the components
Chart Controls for .NET Framework
Chart Controls Add-on for Visual Studio 2008
(2) MODIFY WEB.CONFIG
Add the below as the child node to section
</SPAN>
Add the just after
</SPAN>
Add the just before
(3) Create c:\TempImageFiles folder and give read access to the app pool
Here is a sample markup for user control using Chart control ( replace the highlighted ones with your datasource control and the field or display field name)
</SPAN>
Solutions Monkey: Deploying Ax 2009 SP1 EP Blog bot DAX Blogs 0 05.02.2009 07:08
Solutions Monkey: Microsoft Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks – 3 Blog bot DAX Blogs 0 27.10.2008 08:05
Solutions Monkey: Microsofty Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks - 2 Blog bot DAX Blogs 0 30.09.2008 07:07
Solutions Monkey: Using Microsoft Dynamics Ax 2009 Workflow controls in EP Blog bot DAX Blogs 0 30.07.2008 10:05
Solutions Monkey: How to alternate the background color of each row in Web Grid in EP 4.0? Blog bot DAX Blogs 0 12.01.2008 12:31
Часовой пояс GMT +3, время: 05:42.
