Старый 18.02.2009, 08:05   #1
Solutions Monkey: EP Page Life Cycle
Источник: http://blogs.msdn.com/solutions/arch...ife-cycle.aspx
Here is the sequence of events raised by various controls in a typical list or task page for some common scenarios.
Legend
Green
Common Events for any command
Yellow
Events that are specific to how dataset is constructed depending on if it’s post back or not
Blue
Events specific to the command
Grid – View First Page
Grid – Changing Page
Grid – Change Row Selection
AxDataSource-Init
AxGridView-Init
Page-Init
AxDataSource-CreatingDataSetRun
dataset-init- pre super
datasource-init
dataset-init- post super
AxDataSource-InitializedDataSetRun
Page-Load
AxDataSource-Load
AxGridView-Load
AxDataSource-RunningDataSetRun
dataset-run- pre super
datasource-executeQuery
dataset-run- post super
AxDataSource-Unload
AxGridView-RowCreated ( for each row)
AxBoundField – OnFormattingValue ( for each bound field)
AxGridView-RowDataBound ( for each row)
AxGridView-DataBound
AxGridView-PreRender
dataset-pack
AxDataSource-DataSetDetached
AxDataSource-Unload
AxGridView-Unload
Page-Unload
AxDataSource-Init
AxGridView-Init
Page-Init
dataset-unpack
AxDataSource-DataSetReady
Page-Load
AxDataSource-Load
AxGridView-Load
AxGridView-RowCommand
AxGridView-PageIndexChanging
Table-reread
datasource-reread
datasource-refresh
AxGridView-PageIndexChanged
datasource-research- pre super
datasource-research- post super
AxDataSource-Unload
dataset-pack
AxDataSource-Unload
AxGridView-Unload
Page-Unload
AxDataSource-Init
AxGridView-Init
Page-Init
AxGridView-RowCreated( for each row)
Page-Load
AxDataSource-Load
AxGridView-Load
AxGridView-SelectedIndexChanging
GridView-SelectedIndexChanged
GridView-PreRender
dataset-pack
AxDataSource-Unload
GridView-Unload
Page-Unload
Grid – Save Row edit
Grid – Cancel Row Edit
Grid – Delete Row
AxDataSource-Init
AxGridView-Init
Page-Init
Page-Load
AxDataSource-Load
AxGridView-Load
AxDataSource-RowCommand
AxGridView-RowUpdating
Table-ValidateField
Table-modifiedField
datasource-validateWrite – pre super
Table-validateWrite
datasource-validateWrite – post super
datasource-write – pre super
Table-update – pre super
Table-aosValidateUpdate
Table-update – post super
datasource-refresh
datasource-write- post super
datasource-leaveRecord
AxGridView-RowUpdated
AxDataSource-Unload
dataset-pack
AxDataSource-Unload
AxGridView-Unload
Page-Unload
AxDataSource-Init
AxGridView-Init
Page-Init
Page-Load
AxDataSource-Load
AxGridView-Load
datasource-reread – pre super
Table-reread
datasource-reread – post super
datasource-refresh
datasource-research
AxGridView-RowCancellingEdit
AxDataSource-Unload
dataset-pack
AxDataSource-Unload
AxGridView-Unload
Page-Unload
AxDataSource-Init
AxGridView-Init
Page-Init
Page-Load
AxDataSource-Load
AxGridView-Load
AxGridView-RowDeleting
datasource-validateDelete - presuper
Table-validateDelete
datasource-validateDelete - postsuper
datasource-delete –presuper
Table-delete
datasource-delete –postsuper
GridView-RowDeleted
AxDataSource-Unload
dataset-pack
AxDataSource-Unload
AxGridView-Unload
Page-Unload
Form with a single group control ( if you have multi section/ section controls, their event execution will be similar to that group control in the below list)
Form – View Record
Form – Update Record
Form – Insert Record
AxDataSource-Init
AxGroup-Init
AxForm-Init
Page-Init
dataset-init - presuper
datasource-init
dataset-init - postsuper
Page-Load
AxDataSource-Load
AxForm-Load
dataset-run - presuper
dataset-run - postsuper
AxForm-DataBinding
AxForm-ItemCreated
AxGroup-DataBinding
AxForm-DataBound
AxGroup-Load
AxForm-PreRender
AxGroup-PreRender
dataset-pack
AxDataSource-Unload
AxGroup-Unload
AxForm-Unload
Page-Unload
AxDataSource-Init
AxGroup-Init
AxForm-Init
Page-Init
dataset-unpack
AxForm-ItemCreated
Page-Load
AxDataSource-Load
AxForm-Load
AxGroup-Load
AxForm-ItemCommand
AxForm-ItemUpdating
Table-ValidateField
Table-modifiedField
datasource-validateWrite - presuper
Table-validateWrite
datasource-validateWrite - postsuper
Table-update - presuper
Table-update - postsuper
datasource-refresh
datasource-write
AxForm-ItemUpdated
AxForm-ModeChanging
AxForm-ModeChanged
AxForm-DataBinding
AxForm-ItemCreated
AxGroup-DataBinding
AxForm-DataBound
AxForm-PreRender
AxGroup-PreRender
dataset-pack
AxDataSource-Unload
AxGroup-Unload
AxForm-Unload
Page-Unload
AxDataSource-Init
AxGroup-Init
AxForm-Init
Page-Init
AxForm-ItemCreated
Page-Load
AxDataSource-Load
AxForm-Load
AxGroup-Load
AxForm-ItemCommand
AxForm-ItemInserting
Table-ValidateField
Table-modifiedField
Table-validateWrite
datasource-validateWrite- postsuper
datasource-write - presuper
Table-insert - presuper
Table-aosValidateInsert
Table-insert - postsuper
datasource-refresh
datasource-write - postsuper
AxForm-ItemInserted
AxForm-ModeChanging
AxForm-ModeChanged
AxForm-DataBinding
AxForm-ItemCreated
AxGroup-DataBinding
AxForm-DataBound
AxForm-PreRender
AxGroup-PreRender
dataset-pack
AxDataSource-Unload
AxGroup-Unload
AxForm-Unload
Page-Unload
Solutions Monkey: Integrating EP Web Parts to non-EP SharePoint sites Blog bot DAX Blogs 0 04.04.2009 03:19
Solutions Monkey: w3wp crash while installing EP or creating EP site Blog bot DAX Blogs 0 07.02.2009 08:13
Solutions Monkey: Deploying Ax 2009 SP1 EP Blog bot DAX Blogs 0 05.02.2009 07:08
Solutions Monkey: EP SSL ( https) Setup Blog bot DAX Blogs 0 23.10.2008 12:05
Solutions Monkey: Setting up EP in NLB Cluster Blog bot DAX Blogs 0 18.10.2008 02:08
Часовой пояс GMT +3, время: 04:06.
