Старый 09.09.2008, 01:06   #1
Dynamics AX: Microsoft Certifications and the Learning Curve
Источник: http://dynamics-ax.blogspot.com/2008...-learning.html
I wanted to take the time today and post about some new Microsoft Certifications that you can start to take advantage of. First the Visual Studio 2008 and SQL Server 2008 exams are about to be released. This also brings up the fact that Microsoft now has a new line of certifications called the Master series. It goes beyond the TS and Pro certification levels.
Check out the following diagram: (need PartnerSource Access)
As you can see the Master series in on top. This new Master Series is required now before you can go for an MCA, or Certified Architect.
I recommend checking this out, as it could help seperate you from a crowd. Next I got this wonderful information from the US Partner Learning blog. You can find this blog located here: The US Partner Learning Blog The current top post is talking about the new newsletter, called "The Learning Curve". I recommend you get this and keep on the up and up for new training.
Finally another useful link is the new certification map, in Excel. You can download this here: (PartnerSource Access Required) New Generation Certification Exam Map
So check these great resources out and check back soon!
"Visit the Dynamics AX Community Page today!"
Старый 09.09.2008, 11:31   #2
kashperuk is offline
kashperuk
Аватар для kashperuk
4,361 / 2084 (78) +++++++++
Кто-нибудь посмотрел, о чем рассказывается по приведенным ссылкам?
Расскажите вкратце, будьте добры.
Как это связано с MBS?
Старый 10.09.2008, 22:37   #3
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
Кто-нибудь посмотрел, о чем рассказывается по приведенным ссылкам? Как это связано с MBS?
Вкратце, это все пока касается, я так понимаю, чего угодно кроме MBS Видимо, до Ms Dynamics руки у разработчиков новых программ сертификации пока не дошли... Вообще же, там много информации для компаний-партнеров, какие их сотрудникам надо иметь сертификаты, чтобы партнер мог претендовать на ту или иную компетенцию. К примеру, чтобы партнер мог претендовать на компетенцию Microsoft Business Solutions со специализацией Ms Dynamics AX, компания «должна нанять в штат или по контракту одного или нескольких сотрудников, которые в совокупности должны успешно сдать следующие экзамены»:
  • Microsoft Dynamics AX Development Introduction
  • Microsoft Dynamics AX Financials
  • Microsoft Dynamics AX Installation and Configuration
  • Microsoft Dynamics AX Trade and Logistics
  • а также 70-431 Microsoft SQL Server 2005 – Implementation and Maintenance, либо
  • 70-432 Microsoft SQL Server 2008
При этом экзамены по Ms Dynamics AX должны быть по версии не ниже 4.0.
По ссылке на программу Microsoft Certified Master пока упоминаются только специализации по Microsoft Exchange Server 2007, Microsoft SQL Server 2008 и Windows Server 2008: Directory - про Ms Dynamics ни слова, равно как и про кучу чего еще... В общем, видимо, остальное, как говорится, в разработке.
За это сообщение автора поблагодарили: kashperuk (3).
Старый 11.09.2008, 00:09   #4
kashperuk
Ясно. Почему-то так и предполагал
Ну, мне в любом случае еще даже на MCBMSP работать и работать, поэтому еще выше ступень меня пока не беспокоит
Часовой пояс GMT +3, время: 15:48.
