Старый 23.05.2008, 18:05   #1
Dynamics AX: Calling an Excel Macro from X++
Источник: http://dynamics-ax.blogspot.com/2008...ro-from-x.html
All, recently I needed to know how to call an Excel Macro from X++. This is not something that is widely published anywhere on the web, and something I had to figure out.
It's actually not that hard, and the best help was looking at how I had done it before in .Net.
So here is the code example:
SysExcelApplication ExcelApp;
SysExcelWorkbooks WorkBooks;
SysExcelWorkbook WorkBook;
SysExcelWorksheet Worksheet;
ExcelApp = SysExcelApplication::construct();
ExcelApp.displayAlerts(true);
ExcelApp.visible(true);
ExcelApp.workbooks().open("SomeExcelFile.xls");
Workbook = ExcelApp.workbooks().item(1);
Worksheet = Workbook.worksheets().itemFromName("WorkSheetName");
ExcelApp.comObject().Run("SomeMacro"); // The Call to run a Macro
Of course there is a lot more you can do, but basically any Excel based class has a .comObject() at which you can further extend and make Excel Interop COM calls via, that go beyond what is coded for in the SysExcel Class framework.
Check back soon!
"Visit the Dynamics AX Community Page today!"
Find a job at: DynamicsAXJobs.com, also post a job for only $99.00!
Старый 26.05.2008, 16:39   #2
Gustav is offline
Gustav
Аватар для Gustav
SAP
1,858 / 1152 (42) ++++++++
Записей в блоге: 19
"Давно тут сидим..."
Сообщение от Gustav Посмотреть сообщение
Как вариант с минимальными усилиями: можете попробовать запускать из Аксапты вашу VBA-процедуру в первозданном эксельном виде на невидимом эксельном хосте при помощи следующего джоба:
static void Job_CreateNomenclature(Args _args)
    COM xlApp, wbks, wbk;
    xlApp = new COM('Excel.Application');
    wbks = xlApp.Workbooks();
    wbk  = wbks.Open(@'C:\YourExcelFile.xls');
    xlApp.Run('CreateNomenclature');
Dynamics AX: Microsoft's strategy and vision for Dynamics AX and SOA Blog bot DAX Blogs 0 05.03.2009 18:05
casperkamal: Using ADO to read from Excel in Microsoft Dynamics Ax Blog bot DAX Blogs 2 14.05.2007 11:59
Dynamics AX: Why Dynamics AX beats SAP Blog bot DAX Blogs 0 10.01.2007 23:15
Часовой пояс GMT +3, время: 06:59.
