Старый 03.05.2008, 08:16   #1
Developer notes: Write InfoLog to database
Источник: http://axdevnotes.blogspot.com/2008/...-database.html
There are several batch tasks running on the schedule in our company. They send many messages to InfoLog. Usually I am interesting messages of some type. It is not convenient scroll all messages in SysInfologBrowser form in search of required. I decided to implement the method for writing InfoLog to the database. After investigation of the Info class I wrote code listed below.
protected Log logTxt()
    #resAppl
    #Define.UserTab('\t')
    Integer                 fromIdx  = transLogPoint + 1;
    Integer                 toIdx    = infoLog.num();
    SysInfoLogEnumerator    enum = SysInfologEnumerator::newData(infoLog.copy(fromIdx, toIdx));
    Log                     logTxt;
    DictEnum                dictEnum = new DictEnum(enumNum(Exception));
    while (enum.moveNext())
        logTxt += strFmt("%1 \t %2\r\n",
                            dictEnum.index2Name(enum.currentException()),
                            strRem(enum.currentMessage(), #UserTab));
    transLogPoint = toIdx;
    return logTxt;
Variable transLogPoint keep the value of the last message index before start batch task.
Developer notes: Inventory closing make corrections for transactions in closed periods Blog bot DAX Blogs 2 15.07.2008 20:52
Developer notes: Be careful whith Collections and Maps in Axapta Blog bot DAX Blogs 0 13.05.2008 19:05
Developer notes: Why debit and credit turnovers different in Ledger and Inventory modules? Blog bot DAX Blogs 0 03.05.2008 08:16
Developer notes: Null value for ADO command parameter Blog bot DAX Blogs 0 03.05.2008 08:16
Часовой пояс GMT +3, время: 17:08.
