Старый 15.02.2008, 16:40   #1
axStart: Where is my code running
Источник: http://axstart.spaces.live.com/Blog/...C0A0!259.entry
Sometime you are not for sure if your code is running on the AOS or on the client.
By adding below line in your code. AX will tell you where the code is running.
info(strfmt("%1",xGlobal::clientKind()));
Dynamics Mobile: How to code your own barcode enabled tasklets (Motorola and Intermec devices) Blog bot DAX Blogs 1 03.06.2014 06:34
axStart: How to find line of code with a question mark in your AOT. Blog bot DAX Blogs 0 16.04.2008 22:05
axStart: Starting the code profiler from code Blog bot DAX Blogs 0 17.03.2008 15:05
axStart: What to do when AIF is not working and how to code: Blog bot DAX Blogs 0 23.12.2007 17:51
Часовой пояс GMT +3, время: 03:45.
