Старый 18.01.2008, 13:30   #1
ax-som: BOM explosion
Источник: http://ax-som.blogspot.com/2008/01/bom-explosion.html
Do you want to get the BOMExplosion by code? If so, you could use the
class BOMSearch.
All you need is one method which will be called several times. Example:
void browseThroughBOM(BOMSearch _clsBOMSearch)
    BOM                          LtabBOM;
    InventTable             LtabInventTable;
    while (_clsBOMSearch.next())
         LtabBOM = _clsBOMSearch.BOM();
        LtabInventTable =  LtabBOM.inventTable();
        info(LtabInventTable.ItemId);
         if(LtabInventTable.ItemType ==  ItemType::BOM)
        this.browseThroughBOM(BOMSearch::newBOMIdDate(LtabInventTable.BOMId(syst
        emDateGet()),  systemDateGet()));
You can call this Method with BOMSearch as argument (e.g.
BOMSearch::newBOMIdDate(YourBOMId, systemDateGet()))
ax-som: Number sequnec lock Blog bot DAX Blogs 2 21.01.2008 15:25
Часовой пояс GMT +3, время: 20:14.
