Старый 09.01.2008, 04:34   #1
axStart: version control with VSS by using Labels BETA
Источник: http://axstart.spaces.live.com/Blog/...C0A0!225.entry
I was so happy when I saw that AX 4.0 had VSS integration. However when I start working with it, I found out that it was a little bit limited. My biggest problem was that I was not able to label a release in AX. So I start some programming. With this add-on you are able to create labels in VSS from inside AX. The interface act like this. Create a Project in AX. Open the Project node. Be shore that all objects exist in VSS. Next click right mouse button on top of the Project. And select VSS Create Label. A runbase dialog appear. You can add the label and a command line. By pressing OK the Labeling in AX starts.
The way back is not completed yet. I have added a second class VSSLabelGet. This will read out all xpo that belong to that label. You have to import the xpo you’re self in AX.
The used technology is based on VSS Command lines MSDN
This is the first Beta release any suggestion or change in the code is ok, Please post your idees in the Log and I will update the code.
download xpo
mfp: Dynamics AX 2009 Version Control Interview Blog bot DAX Blogs 0 28.01.2009 12:05
axStart: Microsoft Dynamics AX 2009 White Paper: Team Foundation Server Version Control Setup Blog bot DAX Blogs 0 27.07.2008 13:06
axStart: Ax product version check Blog bot DAX Blogs 1 21.06.2008 23:38
Channel9: Version control in MorphX Blog bot DAX Blogs 8 25.12.2007 10:37
DynamicsTech: How to do the setup for Version Control System in Ax 4.0 Blog bot DAX Blogs 0 12.04.2007 11:50
Часовой пояс GMT +3, время: 23:59.
