Старый 18.12.2007, 19:50   #1
gatesasbait: Showing Database name of current AOS in AX 4.0x title bar
Источник: http://gatesasbait.spaces.live.com/B...B9F5!157.entry
Good morning,
In prior versions of Ax (such as 2.5) you could see the currently running Database name in the title bar of your client. To have this in Dynamics Ax 4.0x, add this code to method 'workspaceWindowCreated' in class 'Info'.
void workspaceWindowCreated(int _hWnd)
    SqlSystem sqlSystem = new SqlSystem();
    if (sqlSystem.createLoginProperty())
        winApi::setWindowText(_hWnd,
            strfmt("%1, Configuration: %2",
                winApi::getWindowText(_hWnd), sqlSystem.loginDatabase()));
gatesasbait: Forcing specific layers to compare in Ax 4.0x Blog bot DAX Blogs 0 18.12.2007 19:50
gatesasbait: About local Dynamics Ax 4.0x installations on Windows XP Blog bot DAX Blogs 0 28.11.2007 06:32
Arijit Basu: AX 4 AOS Basics: [Level 100] Blog bot DAX Blogs 0 18.11.2007 14:30
Dynamics AX: Returning the Current SQL Server, Database, and Configuration Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 07:35.
