Старый 09.11.2007, 12:50   #1
axaptapedia: Packing date range values in queries
Источник: http://www.axaptapedia.com/Packing_d...ues_in_queries
Summary:
<div>A query in default Ax can be packed for patch processing of userdata. When a query is packed, ranges supplied by the user are packed as a text value and this includes date ranges. There is however a problem when the range is unpacked on a computer with a different regional setting than the computer issueing the request.
For example: a dutch user wants a report for sales orders created after the 2nd of november 2007. Enters the value ‘>2-11-2007’ (‘D-M-Y’) in the range field. This is placed in a batch group and run on a batch server with regional settings english (‘D\M\Y’). The report is empty, because the date range resulted in no machtes.
Changing the regional settings so all clients, server and batch server match is offcourse the best solution. But in international scenario's endusers are still able to supply their own formats (there is no validation) and this basicly contradicts the purpose of regional settings. Therefor, the solution could be changing the daterange-value in a generic way. There are two generic storages available: the date2strxpp format : d\m\y (see Global::date2strxpp(...)) and date2num (number of days since 01/01/1900). Since the date2strxpp format is not easy converted back (any2date and str2date does not work) converting to a number is the 'easiest'.
== Alteration in Dynamics Ax ==
For this to work, two alteration have to be made:
- Logic to change the daterage-value to a generic value
- Hook into the packing and unpacking of a query
''Note that this affects all packing of queries, both in batch as in usagedata. It does not affect the UI: user still have to enter the dates using the formatting in their own regional settings, and after unpacking the date value will be in the regional settings of the users.''
''After this change, any saved batch jobs with date ranges and usagedate will have to be re-entered.''
== Logic to change the daterage-value to a generic value ==
To change a daterange-value, the logic has to take into account complex values like:
"!107, 207, 307..407, =507, 707"
So, in case of complex values, this is a challange. For a generic approach the following code looks up the allowed control character like !,= and '..' Any date in between those characters are presumed dates.
Add to following code to the SysQuery class:
// Method : SysQuery::convertDateRangeValue()
// Author : Gerrit Hulleman
// Created : 20071108
// Modified : 20071108
// Purpose : Convert a date range from and to a generic store value.
// History : 20071108 - Initial version
// Parm _conversionType: 0 = Regional 2 Generic
// !0 = Generic 2 Regional
static str convertDateRangeValue(str _rangeValue, int _conversionType)
str dateRangeValue;
int tokenIdx;
int tokenLength;
str tokenValue;
boolean tokenValueIsDate;
str result;
// Find the first entry of a 'control' token(not a date value)
// Sets: tokenIdx
// tokenLength
void loadNextIndex()
int foundIdx;
tokenIdx = strlen(dateRangeValue)+1; // Default -> set to full length
// Find the single-char control tokens
foundIdx = strfind(dateRangeValue, " ,=!'\"", 1, strlen(dateRangeValue));
if (foundIdx && foundIdx < tokenIdx)
tokenLength = 1;
tokenIdx = foundIdx;
// Find the multi char control tokens.
foundIdx = strscan(dateRangeValue, "..", 0, strlen(dateRangeValue));
tokenLength = 2;
// Load the next token
// Sets: tokenValue
void loadNextToken()
// Load the first token data: tokenIdx, tokenLength
loadNextIndex();
if (tokenIdx == 1)
// Found a control token at the beginning of the value. Load token.
tokenValueIsDate = false;
tokenValue = substr(dateRangeValue, tokenIdx, tokenLength);
dateRangeValue = substr(dateRangeValue, tokenLength+1, strlen(dateRangeValue)-tokenLength);
else
// Found a control token further in the value. Date present before the control token.
tokenValueIsDate = true;
tokenValue = substr(dateRangeValue, 1, tokenIdx-1);
dateRangeValue = substr(dateRangeValue, tokenIdx, strlen(dateRangeValue)-tokenIdx+1);
// Converts a date string to and from regional values as string
str convertDateValue()
int dateValueInt;
str localResult;
date dateValue;
if (_conversionType == 0)
// Convert to generic
dateValue = str2date(tokenValue, -1);
dateValueInt = date2num(dateValue); // Number representation of the value
localResult = strfmt("%1", dateValueInt);
else
// Convert to regional
dateValueInt = str2int(tokenValue); // Number representation of the value
dateValue = num2date(dateValueInt);
localResult = date2str(dateValue, -1, -1, -1, -1, -1, -1);
return localResult;
dateRangeValue = _rangeValue;
// Progress the value provided.
while (dateRangeValue)
// Retrieve the next token
loadNextToken();
// If the token is a date, convert. Otherwise, token is a control value and add unconverted.
if (tokenValueIsDate)
result += convertDateValue();
else
result += tokenValue;
return result;
== Hook into the packing and unpacking of a query ==
Now it is up to Ax to convert the daterange-value to a generic value. Ax has a lovely place for this: SysQuery::packDatasource for packing and SysQuery::unpackDataSource for (you guessed it...) unpacking.
In the pack datasource, look for the following code:
// Pack ranges
... // code removed
for (i=1; i = _queryNextUniqueId)
... // code removed
if(! range)
range = queryBuildRange.value();
// Begin modification, 08-11-2007, Ghull
if (range != "")
// Convert a date-range value from regional to generic value
dictField = new SysDictField(queryBuildRange.table(), queryBuildRange.field());
if (dictField.baseType() == Types::Date)
range = SysQuery::convertDateRangeValue(range, 0);
// End modification, 08-11-2007, Ghull
Add the code indicated by the modification comments. Your code might look a bit differently, depending on version and custom code.
For unpacking, look for the following sections in the SysQuery.unpackDataSource
// unpack ranges
_queryBuildDataSource.clearRanges();
rangeNoAddSet = new Set(Types::Integer);
if (_origRangeMap &&
_origRangeMap.exists(_queryBuildDataSource.uniqueId()))
origRangePack = _origRangeMap.lookup(_queryBuildDataSource.uniqueId());
elements = conLen(origRangePack);
for (i=1; i
axaptapedia: Validate field values on form Blog bot DAX Blogs 0 17.12.2008 12:05
palleagermark: Dynamic date ranges in queries Blog bot DAX Blogs 8 07.05.2008 17:03
Fred Shen: Date data type in Query Range Value Expression Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 00:05.
