Старый 06.10.2007, 06:51   #1
Solutions Monkey: Opening Enterprise Portal page in a new window from the Quick Launch
Источник: http://blogs.msdn.com/solutions/arch...ck-launch.aspx
By default the links on the left navigation ( Quick Launch) in Enterprise Portal opens up in the same window replacing the current page.If there is a need to open up specific pages in a new window , )for example you are viewing the sales order list page and the Sales Report link on the left navigation should not replace but open up in new window ), then you can achieve this by changing the url property of the web menu item.
For example , if the URL for EPSalesStatistic ( Sales – All Reports) by default points to Enterprise Portal /EPSalesStatistic.aspx.
Change this to
javascript:void(window.open('EPSalesStatistic.aspx'));
and Refresh AOD to clear the metadata cache on the portal.
From then wherever this link is used, now the page will open in a new window.
Solutions Monkey: Microsoft Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks – 3 Blog bot DAX Blogs 0 27.10.2008 08:05
Solutions Monkey: Microsoft Dynamics AX 2009 Enterprise Portal Quick starts and Screen casts Blog bot DAX Blogs 0 05.08.2008 05:18
Solutions Monkey: Enterprise Portal Screencasts at Channel9.msdn.com Blog bot DAX Blogs 6 01.07.2008 19:38
Solutions Monkey: Microsofty Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks - 1 Blog bot DAX Blogs 0 26.06.2008 09:05
Solutions Monkey: Quick Steps to setup Enterprise Portal in a cluster Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 18:15.
