Старый 02.10.2007, 04:49   #1
Inside Dynamics AX 4.0: RunBase Framework Extension Part III
Источник: http://feeds.feedburner.com/~r/Insid...-part-iii.html
Continue from Part II
Implementing the run Method
You can now write the sendOffers method that contains your business operation as follows.
To call the method, you must add it to the run method, which, as you might remember, is called from the value main if the user clicks OK in the dialog box and the values pass validation. The run method follows a specific pattern, as shown here.
This pattern ensures that the transaction is carried out within the scope of a database transaction and that the execution can recover from a deadlock or update conflict in the database. The run method calls validation again because someone may call run without showing the dialog box. In run, an error is thrown to completely stop the execution if validation fails. (Using the class without showing the dialog box is discussed later in this section.) When you add the call to the sendOffers method that holds your business operation, the run method looks like this.
Implementing the pack and unpack Methods
Now is a good time to revisit the pack and unpack methods. Start in the class declaration by setting up the member variables that you want to store. In this example, you store the createServiceOrders variable. State the version number of the current set of member variables. The version number allows you to add new member variables later and still retrieve the old settings from the last execution of the operation. Also, you can specify the version number to be treated as the first version of the member variable list in the #Version1 declaration. This allows you to treat another version as the first version, which you might choose to do if you simply want to ignore a range of older versions. The first version is typically version 1.
When more variables are stored in the #CurrentList macro, separate each variable by a comma.
The pack method must be changed to follow this specific pattern.
The unpack method must be changed to follow this pattern.
You must also make the following change to your implementation of the dialog method to show the old values in the dialog box fields.
Notice that you call the addFieldValue method rather than the addField method. The addFieldValue method allows you to pass a default value to the dialog box field. The RunBase framework ensures that the variable is set to the value saved in the SysLastValue framework at this point in time.
Creating a Menu Item
To make the operation available from the main menu and the Navigation Pane, you must create a menu item for the operation. The menu item must be attached to a configuration key and a security key.
To create a new configuration key, open the AOT and expand Data Dictionary, right-click Configuration Keys, and then select New Configuration Key. Right-click the new configuration key and select Properties to open the property sheet. Change the name to BikeTuningOffers, and add the label number @USR9 to the Label field. The label should read "Bike-tuning offers." If you want to make the configuration dependent on another configuration key, you should fill in the ParentKey property. For this example, make the configuration key dependent on the Quotation configuration key by entering QuotationBasic in the ParentKey property field.
The security key property for the menu item should be chosen from the existing security keys. The chosen security key must match the position of the menu item on the main menu or in the Navigation Pane. For example, if you wanted to put your menu item under Accounts Receivable\Periodic, the security key must be CustPeriodic.
With the configuration and security keys in place, you are ready to create the menu item. In the AOT, expand Menu Items, right-click Action, and then select New Menu Item. Right-click the new menu item, and then select Properties. Fill out the properties as described in the below table.
Bike-Tuning Menu Item Properties
Tip
You can drag the class node in the AOT onto the Action node under Menu Items to create a new menu item with the same name as the class and the ObjectType and Object properties already defined.
Now add the menu item to the Accounts Receivable submenu. In the AOT, expand Menus, right-click Cust, point to New, and then click Menu Item. Right-click the new menu item, and then select the Properties tab. Change Name to BikeTuningOffers. Change MenuItemType to Action and MenuItemName to BikeTuningOffers. Finally, move the menu item to the Periodic folder of the menu. Save the menu, and then restart the Dynamics AX client to make the new menu item appear in the Navigation Pane and on the Dynamics AX main menu.
Adding Property Methods
Suppose that you want to run the Bike-Tuning Offers business operation directly from another piece of code without presenting the user with a dialog box. To do so, you must implement property methods according to the property method pattern. This pattern allows you to set and get the properties that would otherwise be inaccessible because member variables in Dynamics AX are protected.
Start by writing a parm method for the property as follows.
This job demonstrates how you can run the operation without showing the dialog box.
Related Articles
</img> </img> </img> </img> </img>
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Inside Dynamics AX 4.0: RunBase Framework Extension Part IV Blog bot DAX Blogs 0 02.10.2007 04:49
Inside Dynamics AX 4.0: RunBase Framework Extension Part I Blog bot DAX Blogs 0 30.09.2007 09:20
Inside Dynamics AX 4.0: Wizard Framework Extension Part II Blog bot DAX Blogs 0 29.09.2007 19:00
Часовой пояс GMT +3, время: 04:13.
