		#1 |
			Arijit Basu: Creating Sales Orders via X++
			Источник: http://daxguy.blogspot.com/2007/08/c...ers-via-x.html
			============== For beginner AX developers, I’m listing some codes which will help someone to create Sales Orders (Similar can be applied to PO) via X++ codes. This may be helpful to new Developers. [Level 200] Some important Objects which are to be referred and understood are: -Tables\SalesTable -Tables\SalesLine -Tables\InventDim -Tables\CustTable -Tables\InventTable -Classes\SalesTableType {The InventType Hierarchy} Sample Code [Very basic] static void SalesOrderCreation(Args _args) { SalesTable salesTable; NumberSeq NumberSeq; SalesLine salesLine; InventDim IDim; ; ttsbegin; NumberSeq = NumberSeq::newGetNumFromCode(SalesParameters::numRefSalesId).numberSequence); //=======Table======= salesTable.SalesId = NumberSeq.num(); salesTable.initValue(); salesTable.CustAccount = "4000"; //Enter Customer Acount salesTable.initFromCustTable(); salesTable.InventLocationId = "GW"; salesTable.insert(); //========Line======= salesLine.clear(); salesLine.SalesId = salesTable.SalesId; salesLine.ItemId = "IS2082SAIL"; //Enter Item ID IDim.InventColorId ="CU"; //Enter Item Dimensions IDim.InventLocationId = "GW"; IDim = InventDim::findOrCreate(IDim); salesLine.InventDimId = IDim.inventDimId; salesLine.createLine(NoYes::Yes, NoYes::Yes, NoYes::Yes, NoYes::Yes, NoYes::Yes, NoYes::Yes); //=================== ttscommit; Info(salesTable.SalesId); } The above code is very basic but will help you with the concepts and the same can be extended to create PO Happy DAX-ing :) Источник: http://daxguy.blogspot.com/2007/08/c...ers-via-x.html
	Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору.  |
