Старый 03.08.2007, 23:20   #1
axaptapedia: Howto insert a menu reference into the MainMenu
Источник: http://www.axaptapedia.com/Howto_ins...o_the_MainMenu
Summary:
I don't know how to do it via API (if you call AOTAdd it just inserts given menu itself).
The only way I've foun is to export the MainMenu to XPO, change it, and import again.
Here is example code:
static void Edictum_InstallMainMenu(Args _args)
Menu m=new Menu('MainMenu');
TextBuffer b=new TextBuffer();
str tempFile=WinApi::getTempPath()+'tmp_main_menu.xpo';
int toInsert;
/// find the last occurence of the string _s
int findLast(str _s)
int ret;
int pos = 1;
while(b.find(_s, pos))
ret = b.matchPos();
pos = b.matchPos() + b.matchLen();
return ret;
/// import file by full path
void import(str _fileName)
SysImportElements import=new SysImportElements();
boolean examinedFile=false;
import.newFile(_fileName);
import.parmAddToProject( false);
import.parmDeleteSubNodes(true);
import.parmImportWithIds(false);
import.parmOverrideLocks( false);
import.parmImportLabels(false);
import.parmImportAot(true);
import.import();
// export main menu to the file in the temporary directory
m.treeNodeExport(tempFile);
b.fromFile(tempFile);
// finding the last occurence of menu end
toInsert = findLast('\n: *ENDMENU\n');
if (toInsert)
// insert reference code
b.insert(@'
MENUREFERENCE
PROPERTIES
Name #DOC_Main
ENDPROPERTIES
ENDMENUREFERENCE
', toInsert);
// save the code back to the file
b.toFile(tempFile);
// import changed xpo
import(tempFile);
info('ok');
else
info('bad');
Kashperuk Ivan: Adding Menu ReferencesMany developers often find... Blog bot DAX Blogs 0 26.01.2007 05:51
Axapta Lessons: Menus. Blog bot DAX Blogs 0 23.11.2006 16:00
Axapta Lessons: Menu Items Blog bot DAX Blogs 0 23.11.2006 16:00
Axapta Lessons: Add menu options to the Add-Ins submenu Blog bot DAX Blogs 0 28.10.2006 18:22
Часовой пояс GMT +3, время: 08:33.
