Старый 28.06.2007, 17:00   #1
dynamicsusers: SQL Server: x64 vs x86
Источник: http://dynamicsuser.net/blogs/waldo/...64-vs-x86.aspx
I recently got an interesting explanation on why x64 is more interesting when your system has more than 4 Gb of memory. The background is the size of the memory. An x86 server system can manage a maximum of 4 GB of memory. This limits the addressable memory space for Windows server 2003 systems to 4 GB. (This is true for all 32-bit operating systems). With 2 GB reserved for the operating system by default on 32-bit Windows, only 2 GB of memory remains for SQL 2000 or SQL Server 2005 x86. You can...(read more)
dynamicsusers: Making NAV use a certain index on SQL Server Blog bot DAX Blogs 0 21.08.2007 10:40
Часовой пояс GMT +3, время: 10:28.
