Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 22.11.2006, 20:25   #1
gb is offline
gb
? New behaviour on forms after KR2 release
Hello,
If you have KR2 deployed, go to any form and set filter on any field and then try to create new record ( CTRL+N). Your filter will disappear. Before KR2 deployment the filter would stay.
The other new thing can be demostrated in LedgerJournalSplitPosting. You can't set a focus on a lower grid just by clicking on it ( it used to work always). Now you need to do a left click then right click ( this is a work around ) to get a focus.
The solution to this one was to change property on the datasource: InsertIfempty to 'Yes'. Then you can just highlight the empty buffer and continue with entering data.
I didn't see any mentioning in the release docs from Microsoft. I am wondering what other things are out there.
I appreciate any comments.
Thanks,
gb
За это сообщение автора поблагодарили: glibs (1).
Старый 22.11.2006, 20:48   #2
glibs is offline
glibs
Member
Сотрудники компании It Box
4,942 / 911 (40) +++++++
Сообщение от gb
Such behavior can also be reproduced in KR3, unfortunately.
Thanks for info.
glibs®
Старый 22.11.2006, 23:33   #3
gb is offline
gb
I am hoping that there is an easy way to keep that filter on the data source.
May be somebody already found a solution and can share.
Thanks,
gb
axStart: Get your forms back in one workspace Blog bot DAX Blogs 0 10.12.2008 14:05
X++: Using graphics in forms and legacy reports. Blog bot DAX Blogs 0 01.05.2008 05:20
Kashperuk Ivan: Microsoft Dynamics AX 2009 CTP3 release is available on PartnerSource Blog bot DAX Blogs 35 10.04.2008 20:05
mfp: Now available: Dynamics AX 2009 Pre-Release (CTP3) Demonstration Toolkit Blog bot DAX Blogs 0 26.03.2008 18:05
Dynamics AX: Microsoft Dynamics™ Mobile 2008 - Pre-release of Framework Blog bot DAX Blogs 0 11.01.2008 06:14
Часовой пояс GMT +3, время: 00:32.
