Старый 13.11.2006, 22:30   #1
mfp: Building a layer file from XPO files
Источник: http://blogs.msdn.com/mfp/archive/20...xpo-files.aspx
So now you are using version control - and you just realized the master is no longer the AOD layer file, but instead a zillion of XPO files. Still you want to provide an AOD file to your consumers, as that is the way to deploy an AX application.
Page 88 in Inside Dynamics AX 4.0 contains a description on how to build an AOD file from XPO files. In this section an SDK and a tool are mentioned. While we are working on providing you with the SDK for building a layer file, I can make the CombineXPOs.exe tool available.
See the attached file.
Usage: CombineXPOs.exe XPOfolder DestinationFile.xpo
Example: CombineXPOs.exe USR myFile.xpo
Files in the XPOFolder folder must match the AOT structure. This is automatically ensured when using AX version control integration.
xpo, импорт, полезное, сравнение, сравнение объектов
XPO file viewer Blog bot DAX Blogs 1 19.02.2009 16:52
axaptabuilder: How to build Axapta application from XPO files stored in Visual Source Safe. Blog bot DAX Blogs 0 12.04.2007 16:10
axaptabuilder: How to build Axapta application from XPO files stored in Visual Source Safe. Blog bot DAX Blogs 0 22.11.2006 15:20
Dynamics AX Geek: Deleting all objects from a custom layer Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 01:48.
