Старый 28.10.2006, 16:40   #1
Fred Shen: Create a new method in runtime
Источник: http://fredshen.spaces.live.com/Blog...E4E3!172.entry
Some one may need to use codes to create or edit a method in Axapta.
Here is an example to show how to create a lookup method for a form's field in runtime.
    static void CreateFieldMethod(Args _args)
        TreeNode tn1,tnAddr, methodsNode;
        MemberFunction memberFunction;
        str source;
        //Thanks for Max Belugin's comments,
        //it is really good to use Verbatim String as well.
        //The reason why I use escape characters here is
        //because this line of code is copied from standard Axapta application :)
        tn1 = infolog.findNode(
"\Forms\Address\Data Sources\Address\Fields\AddrRecId");
        tnAddr = infolog.findNode( "
\Forms\Address" );
        methodsNode = tn1.AOTfindChild( 'Methods' );
        methodsNode.AOTadd('lookup');
        memberFunction = methodsNode.AOTfindChild( 'lookup' );
        source =
@"public void lookup(FormControl _formControl, str _filterStr)
                                super(_formControl, _filterStr);
        memberFunction.AOTsetSource(source, false);
        memberFunction.AOTsave();
        methodsNode.AOTsave();
        tnAddr.AOTcompile();
Fred Shen: Failed to create COM objects on AX 4 AOS Blog bot DAX Blogs 0 08.12.2006 19:14
Fred Shen: Change the combobox options in RunbaseBatch class Blog bot DAX Blogs 0 28.10.2006 16:40
Fred Shen: Limited sessions in Axapta Blog bot DAX Blogs 0 28.10.2006 16:40
Fred Shen: Development Features of Dynamics Ax (Axapta) 4.0 Blog bot DAX Blogs 0 28.10.2006 16:40
Fred Shen: Access a method of formDataSource's field Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 03:25.
