Старый 28.10.2006, 16:40   #1
Fred Shen: 'Not Like' in Dynamics AX
Источник: http://fredshen.spaces.live.com/Blog...E4E3!182.entry
In X++, we can use Like '*someIdentifier' to implement the Like keyword.
e.g.
    select firstonly purchTable
        where purchTable.purchId like '00007*';
However if you want to use 'Not Like' in X++ SQL statement, you have three options:
The first option, using '!' as 'not',
e.g.
         where !(purchTable.purchId like '00007*');
The second option, using notExists join
e.g.
    PurchTable purchTable, refPurchTable;
        notExists join refPurchTable
        where purchTable.purchId == '00007*';
Please make sure that you do put purchTable.purchId in condition statement, otherwise the SQL statement will retrieve an empty result set.
The last option, using Query
e.g.
    Query query = new Query();
    QueryRun queryRun;
    query.addDataSource(tableNum(PurchTable)).addRange(fieldNum(PurchTable, PurchId)).value('!00007*');
    queryRun = new QueryRun(query);
    if(queryRun.next())
        purchTable = queryRun.get(tableNum(PurchTable));
        print purchTable.PurchId;
        pause;
Using NotExists join seems more complicated than the first option, but actually there is no performance difference between them.
Fred Shen: Consuming a Web Service in Dynamics AX 4 Blog bot DAX Blogs 0 28.10.2006 16:40
Fred Shen: RefRecID in Dynamics AX 4 Blog bot DAX Blogs 0 28.10.2006 16:40
Fred Shen: Development Features of Dynamics Ax (Axapta) 4.0 Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 05:50.
