Старый 28.10.2006, 16:40   #1
Dynamics AX: Make us of Outbound web services using AIF
Источник: http://dynamics-ax.blogspot.com/2006...ces-using.html
Currently in Dynamics AX 4.0 there is a known bug with Outbound web service adapters and the AIF. This known bug will be fixed in the up coming release of SP1. I did however find a great blog posting by David Pokluda who gives a very detailed example / how to that allows you to by pass the bug and make use of Outbound web service calls. So check it out below:
David Pokluda's blog : Outbound web service (AIF)
Dynamics AX: DAXGuy: Infopath, Web Services & AX Integration Blog bot DAX Blogs 0 08.05.2008 03:18
Consuming External Web Services (Dynamics AX 4) Blog bot DAX Blogs 0 19.02.2008 06:41
Inside Dynamics AX 4.0: The Web Framework Blog bot DAX Blogs 0 25.10.2007 03:04
Pokluda: Outbound web service (AIF) Blog bot DAX Blogs 0 28.10.2006 17:43
Часовой пояс GMT +3, время: 08:36.
