Старый 28.10.2006, 16:40   #1
Palle Agermark: isTypeTime
Источник: http://blogs.msdn.com/palle_agermark...28/681310.aspx
Checking if a certain data field is of the ”time” data type is not as obvious as you may think. Your first few attempts will most likely just tell you that the type of your field is Integer. Here’s a job with a small snippet of code showing you how to...(read more)
Palle Agermark: Is there anything Excel isn't a good tool for? Blog bot DAX Blogs 0 28.10.2006 16:40
Palle Agermark: Activating a custom toolbar Blog bot DAX Blogs 0 28.10.2006 16:40
Palle Agermark: List the datasources of a query object Blog bot DAX Blogs 0 28.10.2006 16:40
Palle Agermark: What does inputSearch do Blog bot DAX Blogs 0 28.10.2006 16:40
Palle Agermark: Debugging queries (kind of) Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 13:42.
