Старый 22.02.2021, 08:43   #2
S.Kuskov is offline
S.Kuskov
3,449 / 1792 (66) ++++++++
Действительно странно. Вот здесь написано что такой возможности нет https://docs.microsoft.com/en-us/dyn...vs-overloading
Overriding vs. Overloading
Overloading is where there is more than one method with the same name, but the methods have different signatures (return type or parameter lists or both).
Overriding is where the superclass's implementation of a method is altered by the subclass's implementation of the method, but the signatures of both methods are the same.
X++ supports overriding, but it does not support overloading
alirazazaidi: Out of the box workflow list Dynamics 365 for Finance and Operations Blog bot DAX Blogs 0 07.10.2019 16:48
daxmusings: AX2012 Extension Framework Blog bot DAX Blogs 0 12.11.2014 09:11
kamalblogs: Error: SSRS/EP error when the return type in display method is incorrect – Dynamics AX 2012 Blog bot DAX Blogs 0 11.10.2013 12:11
Часовой пояс GMT +3, время: 12:36.
