Старый 22.01.2021, 15:46   #1
trud is offline
trud
1,039 / 1635 (57) ++++++++
Записей в блоге: 1
Круто выглядит. А как вы этого добились? я что-то думал что прогресс бар убрали
Старый 22.01.2021, 16:54   #2
kair84 is offline
kair84
Работает только для SysOperation, в Asynchronous и ReliableAsynchronous режимах.
Важно параметризировать parmShowProgressForm(true) в контроллере, и в сервисе получить RunbaseProgress.
Вот код:
Controller
class Test_SysOperationController extends SysOperationServiceController
    protected void loadFromSysLastValue()
        if (!dataContractsInitialized)
            // This is a bug in the SysOperationController class
            // never load from syslastvalue table when executing in batch
            // it is never a valid scenario
            if (!this.isInBatch())
                super();
            dataContractsInitialized = true;
    public void new()
        super();
        // defaulting parameters common to all scenarios
        // If using reliable async mechanism do not wait for the batch to
        // complete. This is better done at the application level since
        // the batch completion state transition is not predictable
        //this.parmRegisterCallbackForReliableAsyncCall(false);
        // default for controllers in these samples is synchronous execution
        // batch execution will be explicity specified. The default for
        // SysOperationServiceController is ReliableAsynchronous execution
        //this.parmExecutionMode(SysOperationExecutionMode::ReliableAsynchronous);
        this.parmExecutionMode(SysOperationExecutionMode::Asynchronous);
        //this.parmExecutionMode(SysOperationExecutionMode::Synchronous); // ProgressBar doesn't work.
        this.parmShowProgressForm(true);
        this.parmClassName(classStr(Test_SysOperationService));
        this.parmMethodName(methodStr(Test_SysOperationService, runOperation));
        //this.parmMethodName(methodStr(Test_SysOperationService, runOperationResult)); // Doesn't work ???
    public ClassDescription caption()
        return 'Test SysOperation !';
    protected boolean canRunInNewSession()
        return true;
    public void asyncCallbackVoid(AsyncTaskResult _asyncResult)
        info("Async Callback Void");
        super(_asyncResult);
        SysOperationDataContractInfo contractInfo = this.getDataContractInfoObjects().lookup("dataContract");
        Test_SysOperationDataContract dataContract = contractInfo.dataContractObject();
        //Box::info("Async Callback  Void Box");
        //this.sendFile("Async Callback Void");
    public void asyncCallbackReturnValue(AsyncTaskResult _asyncResult, anytype _returnValue)
        // Doesn't work ???
        info("Async Callback Result");
        //super(_asyncResult,_returnValue);
        //Box::info("Async Callback  Result Box");
    public void sendFile(str _fileContent)
        Filename filename = "file.csv";
        System.Byte[] byteArray =  System.Text.Encoding::Unicode.GetBytes(_fileContent);
        System.IO.MemoryStream stream = new System.IO.MemoryStream(byteArray);
        stream.Position = 0;
        File::SendFileToUser(stream, fileName);
        info(strFmt("File %1 Sent to user",filename));
    public static void main(Args args)
        Test_SysOperationController operation;
        operation = new Test_SysOperationController();
        operation.startOperation();
DataContract
[DataContractAttribute,
SysOperationContractProcessingAttribute(classStr(Test_SysOperationUIBuilder))]
    class Test_SysOperationDataContract extends SysOperationDataContractBase
    int duration;
    [DataMemberAttribute,
        SysOperationLabelAttribute('Duration (sec.)'),
        SysOperationHelpTextAttribute('Type some number >= 0'),
        SysOperationDisplayOrderAttribute('1')]
    public int parmDuration(int _duration = duration)
        duration = _duration;
        return duration;
UIBuilder
class Test_SysOperationUIBuilder extends SysOperationAutomaticUIBuilder
    DialogField durationField;
    public void postBuild()
        super();
        // get references to dialog controls after creation
        durationField = this.bindInfo().getDialogField(this.dataContractObject(), methodStr(Test_SysOperationDataContract, parmDuration));
    public void postRun()
        super();
        // register overrides for form control events
        durationField.registerOverrideMethod(methodstr(FormIntControl, validate), methodstr(Test_SysOperationUIBuilder, durationFieldValidate), this);
    public boolean durationFieldValidate(FormIntControl _control)
        if (_control.value() < 0)
            error('Please type a number >= 0');
            return false;
        return true;
Service
class Test_SysOperationService extends SysOperationServiceBase
    public void runOperation(Test_SysOperationDataContract dataContract)
        RunbaseProgress                 progress = this.getProgressController(dataContract);
        int total = dataContract.parmDuration();
        progress.setTotal(total);
        int i;
        for (i = 1; i <= total; i++ )
            progress.incCount();
            progress.setText(strFmt("%1 / %2",i,total));
            progress.update(true);
            sleep(1000);
        info('Done!');
    public container runOperationResult(Test_SysOperationDataContract dataContract)
        this.runOperation(dataContract);
        return [dataContract.parmDuration()];
Может кто то подскажет, почему не работает asyncCallbackReturnValue(..) для parmMethodName(methodStr(Test_SysOperationService, runOperationResult)) ?
Выбрасывается ошибка что нет такого метода но вот же он... ???
За это сообщение автора поблагодарили: Logger (5).
Старый 26.01.2021, 18:06   #3
kair84 is offline
kair84
C asyncCallbackReturnValue(..) разобрался, это баг в стандартном методе SysOperationServiceController.asyncCallbackReturnValue(..). Колбэк возвращаяет одну переменную, значит второй параметр нужно сделать необязательным.
Вот так все хорошо, и _returnValue имеет правильное значение, ровно то что вернул метод сервиса.
    public void asyncCallbackReturnValue(AsyncTaskResult _asyncResult, anytype _returnValue  = _asyncResult.getResult())
        info(strFmt("Async Callback Result: %1",con2Str(_returnValue)));
Последний раз редактировалось kair84; 26.01.2021 в 18:14.
За это сообщение автора поблагодарили: madm (1).
Старый 27.01.2021, 12:52   #4
kair84 is offline
kair84
Вижу что тема Вам не сильно интересна, хотя казалось что даже очень.
Чтоб закрыть её, вот как можно сделать прогресс для обычного RunBase :
class Test_RunBaseBatch extends RunBaseBatch
    DialogField     dfDuration;
    // Packed variables
    int             duration;
    str             csvFileContent;
    Email           email2Send;
    guid            callId;
    #define.CurrentVersion(1)
    #localmacro.CurrentList
        callId,
        duration,
        csvFileContent,
        email2Send
    #endmacro
    SysOperationProgressWait progressWait;
    //SysProgress sysProgress;
    public object dialog()
        DialogRunbase dialog;
        dialog = super();
        dfDuration = dialog.addFieldValue(identifierStr(Integer),duration,"Duration (Sec.)");
        return dialog;
    public boolean getFromDialog()
        boolean ret;
        ret = super();
        duration = dfDuration.value();
        email2Send = SysUserInfo::getUserEmail(curUserId());
        return ret;
    public container pack()
        return [#CurrentVersion,#CurrentList];
    public void runAsync()
        callId = newGuid();
        progressWait = SysOperationProgressWait::construct();
        progressWait.parmCallId(callId);
        progressWait.parmCaption(this.caption());
        progressWait.parmBatchTaskId(0);
        xGlobal::runAsyncWithObjectCallback(
            classNum(Test_RunBaseBatch),
            staticMethodStr(Test_RunBaseBatch, doRunAsync),
            this.pack(),
            this, methodStr(Test_RunBaseBatch, runAsyncCallback));
        Message::Add(MessageSeverity::Informational ,"Start Operation Async");
        progressWait.beginWaiting();
    private void runAsyncCallback(AsyncTaskResult _result)
        progressWait.endWaiting();
        Message::Add(MessageSeverity::Informational ,"End Operation Async");
        container parms = _result.getResult();
        this.unpack(parms);
        this.runAfterOperation();
    private static container doRunAsync(container _parms, System.Threading.CancellationToken cancellationToken)
        Test_RunBaseBatch runbase = new Test_RunBaseBatch();
        runbase.unpack(_parms);
        runbase.run();
        return runbase.pack();
    public void run()
        Message::Add(MessageSeverity::Informational ,"run");
        if (! this.validate())
        throw error("");
        SysOperationProgressServer progressBar = new SysOperationProgressServer(1,false,callId);
        progressBar.setCaption("SysOperationProgressServer !!!");
        progressBar.setTotal(duration);
        commaStreamIo iO = commaStreamIo::constructForWrite();
        container header = ["Num"];
        iO.writeExp(header);
        int i;
        for (i=1; i<=duration; i++)
            iO.write(i);
            progressBar.incCount();
            progressBar.setText(strFmt("%1 / %2",i,duration));
            sleep(1000);
        System.IO.Stream stream = iO.getStream();
        System.IO.StreamReader reader = new System.IO.StreamReader(stream);
        csvFileContent = reader.ReadToEnd();
        if (this.isInBatch())
        Message::Add(MessageSeverity::Informational ,"Done!");
    public void runAfterOperation()
        info("runAfterOperation");
        System.Byte[] byteArray =  System.Text.Encoding::Unicode.GetBytes(csvFileContent);
            if (SysEmailDistributor::validateEmail(email2Send))
                SysMailerMessageBuilder messageBuilder = new SysMailerMessageBuilder();
                messageBuilder.setFrom(email2Send,"@SYS115063")
                            .addTo(email2Send)
                            .setPriority(1)
                            .setSubject(this.caption())
                            .setBody(this.caption())
                            .addAttachment(stream, fileName);
                SysMailerFactory::sendNonInteractive(messageBuilder.getMessage());
                info(strFmt("CSV file %1 Sent to user on e-mail %2",filename,email2Send));
        else
            info(strFmt("CSV file %1 Sent to user",filename));
    public boolean unpack(container packedClass)
        Version version = RunBase::getVersion(packedClass);
        switch (version)
            case #CurrentVersion:
                [version,#CurrentList] = packedClass;
                break;
            default:
                return false;
        return true;
    public boolean validate(Object _calledFrom = null)
        if (false)
        return checkFailed("");
        return true;
    static ClassDescription description()
        return "Test RunBase Descr.";
        Test_RunBaseBatch    runBase;
        runBase = new Test_RunBaseBatch();
        runBase.init();
        if (runBase.prompt())
            runBase.runAsync();
        return false;
Очевидно, что для того, чтобы во время выполнения кода на сервере была возможность взаимодействовать с пользователем, необходимо выполнять операцию асинхронно, а для того, чтобы связать серверный процесс с интерфейсом стали использовать таблицу SysProgress, в нее пишется вся необходимая информация о прогрессе (один или несколько прогресс-баров, заголовок, текст, и т.д) и обновляется в время выполнения.
Надеюсь проделанная мной работа не напрасна и пригодится кому то еще кроме меня. Возможно даже удостоится переноса в Блог.
За это сообщение автора поблагодарили: trud (10).
#страшнодалекиониотнарода
mfp: X++ in AX7: String truncation Blog bot DAX Blogs 6 29.05.2020 18:24
mfp: What is new in X++ in AX7? Blog bot DAX Blogs 2 10.02.2016 00:29
Пример использования RunBuf Mechanizm DAX: Программирование 11 02.03.2004 13:25
Пример использования класса RunBase* Andronov DAX: Программирование 3 17.09.2003 13:12
HB_Tutorial_setTmpData - пример использования метода setTmpData vitk DAX: База знаний и проекты 0 10.12.2001 15:26
Часовой пояс GMT +3, время: 01:27.
