Посмотрите global\date2StrXpp по перекрёстным ссылкам, например вот так это выглядит в методе SalesLine\buildDateRangeStr ax2013 r3
X++: /// <summary> /// build date range string with confirmed date. If confirmed is not filled, build with requested date. /// </summary> /// <param name="_dataSourceName"> /// The data source name which need the range. /// </param> /// <param name="_fieldNameConfirmed"> /// The field name of confirmed date. /// </param> /// <param name="_fieldNameRequested"> /// The field name of requested date. /// </param> /// <param name="_dateFrom"> /// The from date for the range. /// </param> /// <param name="_dateTo"> /// The to date for the range. /// </param> /// <returns> /// The query range string. /// </returns> public static str buildDateRangeStr(str _dataSourceName, str _fieldNameConfirmed, str _fieldNameRequested, date _dateFrom, date _dateTo) { if (_dateTo == dateNull()) { _dateTo = dateMax(); } //we select based on confirmed and if confirmed is not filled we add criteria on requested. return strFmt("(((%5.%1 != %6) && (%5.%1 >= %3) && (%5.%1 <= %4)) || ((%5.%1 == %6) && (%5.%2 >= %3) && (%5.%2 <= %4)))", _fieldNameConfirmed, _fieldNameRequested, date2StrXpp(_dateFrom), date2StrXpp(_dateTo), _dataSourceName, date2StrXpp(dateNull())); }
Sergey Nefedov |
