Старый 20.05.2011, 11:11   #1
X++: X++ script host.
Источник: http://blogs.msdn.com/b/x/archive/20...ript-host.aspx
I was looking at the API that we publish for the X++ compiler, and it struck me that it would be really easy to implement a script host for X++. This is a program that allows you to execute arbitrary X++ code that is stored in files in the file system. In this way, you can use X++ as a systems programming language, starting things at particular times etc. I thought it would be fun to see what it takes to implement that command line tool. In the spirit of sharing, I am listing the C# code below. It is, after all, only just over 100 lines of code. Let's imagine that we have a file called MyFile.xpp containing the following:
PHP код:
real f(int ireal rstr s)
System.Console::WriteLine("Hello world");
    return
strlen(s);
With the script host installed, you can do things like:
C\> XppScriptHost MyFile.xpp 3 3.141 "I am an argument".
The script host will return a code to the operating system, so that decisions can be made in script files etc. You could even register the file type (Xpp in this case) with the operating system, so that clicking on the xpp file will automatically start the script (but you will not be able to pass parameters). This is really easy in Windows: You just right click in the .xpp file, and the system will ask you to identify the program to use to open the file. Select this tool and you're in business.
There is certainly room for improvement to this: You could introduce parameters for each of the four arguments passed to the logon call if that is useful in your scenarios. I did not do so here for the sake of simplicity.
Since the business connector is compiled against an earlier version of .NET (to be compatible with the sharepoint pieces), you will need to tell the command line tool that it is should support the earlier framework. You cannot use .NET 2, because the LINQ stuff in the code would not run in that case. Feel free to rewrite that if you must. I just use a configuration file (app.Config) with the following content:
PHP код:
<?xml version="1.0"?>
<configuration>
  <startup>
    <supportedRuntime version="v2.0.50727"/>
  </startup>
</configuration>
Here is the source code in all its glory
PHP код:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
namespace
Microsoft.Dynamics.Ax.XppScriptExecutor
using Microsoft.Dynamics.BusinessConnectorNet;
using System.IO;
/// <summary>
    /// Command line tool to evaluate X++ snippets as functions provided in a
    /// file that is provided as parameter. Any number of parameters may follow,
    /// and these are used as parameters to the method. The result is written to
    /// stdout.
    /// </summary>
class XppScriptHost
/// <summary>
        /// Entry point to the console application.
        /// </summary>
        /// <param name="args">The arguments passed from the command line.</param>
        /// <returns>
        /// <list type="bullet">
        /// <item>0 if all was well</item>
        /// <item>1 if the file was not found</item>
        /// <item>2 if the script contains errors</item>
        /// <item>3 if the some other error happened</item>
        /// </list>
        /// </returns>
static int Main(string[] args)
            if (
args.Length || args.Contains("-help"StringComparer.OrdinalIgnoreCase))
System.Console.Error.WriteLine("XppScriptHost filename parameter...");
System.Console.Error.WriteLine("    The filename must denote a file containing an X++ function.");
System.Console.Error.WriteLine("    The following arguments are interpreted as parameter values.");
System.Console.Error.WriteLine("    The result returned from the X++ function is printed on stdout.");
System.Console.Error.WriteLine("    The X++ code can use System.Console::WriteLine(...) to print output");
System.Console.Error.WriteLine("");
System.Console.Error.WriteLine("XppScriptHost -help");
System.Console.Error.WriteLine("    Writes this message.");
                return
0;
            var
source string.Empty;
            try
using (var stream = new StreamReader(args[0]))
source stream.ReadToEnd();
            catch (
Exception e)
System.Console.Error.WriteLine("File " args[0] + " could not be opened.");
System.Console.Error.WriteLine(e.Message);
                return
1;
Axapta ax = new Axapta();
            try
ax.Logon(nullnullnullnull);
AxaptaObject xppCompiler ax.CreateAxaptaObject("XppCompiler");
                var
success = (bool)xppCompiler.Call("compile"source);
                if (!
success)
// An error occurred during compilation. Get the error messages.
var messages xppCompiler.Call("errorText") as string;
System.Console.Error.WriteLine(messages);
                    return
2;
// The compilation proceeded without error. Now execute it.
                // Push parameters on the X++ stack
xppCompiler.Call("startArgs");
                foreach (var
arg in args.Where(arg => !arg.StartsWith("-")).Skip(1))
int ival;
decimal dval;
                    if (
arg.StartsWith("\"") && arg.EndsWith("\""))
xppCompiler.Call("setStrArg"arg.TrimStart('"').TrimEnd('"'));
                    else if (
int.TryParse(argout ival))
xppCompiler.Call("setIntArg"ival);
                    else if (
decimal.TryParse(argout dval))
xppCompiler.Call("setRealArg"dval);
                    else
xppCompiler.Call("setStrArg"arg);
xppCompiler.Call("endArgs");
                var
xppCompiler.Call("executeEx");
// Write the return value to stdout.
System.Console.Out.WriteLine(o.ToString());
                return
0;
            catch (
Exception e)
System.Console.Error.WriteLine("Error during execution");
                return
3;
            finally
ax.Logoff();
Последний раз редактировалось Poleax; 20.05.2011 в 13:07. Причина: оформление
Старый 22.06.2020, 15:13   #2
Э-э-э-э... Серьезно? Так можно было?
emeadaxsupport: You get a Script Error when viewing Role Centers (deployed on SharePoint 2010) in a Microsoft Dynamics AX 2009 Client Blog bot DAX Blogs 0 04.01.2011 20:11
Kashperuk Ivan: Editor script for simplifying the search in AOT Blog bot DAX Blogs 11 07.01.2010 12:23
Solutions Monkey: Setting Up EP with host headers Blog bot DAX Blogs 0 15.05.2009 09:06
mscrm4ever: CRM Form Script Loader Blog bot Dynamics CRM: Blogs 0 21.04.2009 04:07
Часовой пояс GMT +3, время: 03:01.
