Старый 23.12.2019, 11:33   #7
VORP is offline
VORP
Аватар для VORP
147 / 95 (4) ++++
Method showQueryValues is called upon dialog initialization(/Classes/RunBaseDialogModify/Methods/init - (623, 10)), depending on it query button will be added. So if you modify it when dialog already initialized nothing happens. You should hide button manually, maybe looking at initQuery methods will be useful. But event after that you need to reset query if required, because it will be used even if its invisible.
axapta 2012, hide, select button, show
emeadaxsupport: Microsoft Dynamics AX general performance analysis scripts page 5 Blog bot DAX Blogs 0 01.09.2014 14:11
dynamicscare: Using Power BI to Analyze Your Dynamics AX Data Blog bot DAX Blogs 1 06.10.2013 18:11
atinkerersnotebook: Using Service Management to Track Service Orders Blog bot DAX Blogs 1 25.08.2013 19:16
daxline: How to show or hide query ranges on dialogs in Dynamics AX? Blog bot DAX Blogs 0 03.08.2011 09:11
Часовой пояс GMT +3, время: 20:48.
