Старый 11.11.2019, 19:38   #5
alicedr is offline
alicedr
на ВМ где все работает как надо, запись в MCRSalesTable создается когда пользователь нажимает кнопку Submit (это MCRSalesOrderRecap.SubmitOrder()). Call stack с ВМ где запись создается - на скриншоте внизу.
MCRSalesTable.Insert() делается на Salestable.update():
public class SysExtensionSerializerMap extends common
    /// <summary>
    /// Updates / inserts the packed extension table record after the base table record is updated.
    /// </summary>
    /// <remarks>
    /// This method should be called immediately after super() of base table's <C>update</C> method.
    /// </remarks>
    public void postUpdate()
        SysExtensionSerializerExtensionMap      currentExtensionTable;
        SysExtensionSerializerExtensionMap      extensionTableToUpdate;
        SysExtensionSerializerExtensionMap      extensionTableInUse;
        int                                     i;
        boolean                                 checkForLinkedExtensionTables;
        container                               newPackedExtensions;
        boolean                                 updated;
        Array                                   extensionTableArray = new Array(Types::Record);
        container                               extensionTableTableIdList;
        TableId                                 currentExtensionTableTableId;
        container                               hasLinkedExtensionTableCon;
        boolean                                 hasLinkedExtensionTable;
        if (this.RecId && this.PackedExtensions != conNull())
            for (i = 1; i <= conLen(this.PackedExtensions); i++)
                currentExtensionTable = con2Buf(conPeek(this.PackedExtensions, i));
                extensionTableArray.value(i, currentExtensionTable);
                currentExtensionTableTableId = currentExtensionTable.TableId;
                // if buffer is not form DS there is no need to check for extension table on client
                checkForLinkedExtensionTables = checkForLinkedExtensionTables || FormDataUtil::isFormDataSource(this);
                extensionTableTableIdList += [currentExtensionTableTableId];
            if (checkForLinkedExtensionTables)
                hasLinkedExtensionTableCon = SysExtensionSerializerFormRunHelper::hasExtensionTable(this, extensionTableTableIdList);
            ttsbegin;
            for (i = 1; i <= extensionTableArray.lastIndex(); i++)
                updated = false;
                currentExtensionTable = extensionTableArray.value(i);
                // If it is not an existed record, insert it.
                if (updated == false)
                    currentExtensionTable.BaseRecId = this.RecId;
                    currentExtensionTable.insert();  //<<-----------------------------
                newPackedExtensions += [buf2Con(currentExtensionTable, true)];
            ttscommit;
            this.PackedExtensions = newPackedExtensions;
Миниатюры
mcrsalestable, packedextensions, sysextensionserializermap
sertandev: How to receive D365FO push notifications using Azure Notification Hubs Blog bot DAX Blogs 0 04.07.2019 18:11
sertandev: How to integrate D365FO with Microsoft Flow using the new Business Events Blog bot DAX Blogs 0 23.05.2019 16:11
d365technext: Pass field value from SalesTable to CustTrans in AX 2012 & D365FO Blog bot DAX Blogs 0 15.11.2018 09:11
erconsult: Copy-paste with keyboard script 2: from Excel to D365FO Blog bot DAX Blogs 0 03.08.2018 11:12
littleax: Part1. Dynamics ax 2012. Split construct method by models. Blog bot DAX Blogs 0 28.05.2014 10:11
Часовой пояс GMT +3, время: 00:54.
