Старый 26.08.2004, 11:34   #2
Polar is offline
Polar
Аватар для Polar
281 / 74 (3) ++++
I had the same problem...
This error apears when you have two objects of the same record.
PurchaseHeader1 and PurchaseHeader2 for instance.
PHP код:
PurchaseHeader1.GET("Document Type"::Order,'PH00001');
PurchaseHeader2.GET("Document Type"::Order,'PH00001');
PurchaseHeader1.SomeField:=SomeValue;
PurchaseHeader1.MODIFY;
// after this you'll have problems with PurchaseHeader2
// 'cause in cache PurchaseHeader2 differs quite from
// Purchase Header in SQL database
//therefore you should make
//and then error will disappear
I suppose the problem is in your local modifications
Удачи!
Navision 2.5 SQL option. Error during database creation Leon NAV: Администрирование 2 02.08.2006 12:33
Navision Database Server c0der NAV: Администрирование 2 27.05.2005 22:37
Navision - SQL Server. Открытие БД. Mary NAV: Администрирование 0 30.03.2005 19:03
Navision Database Server Mad_lena NAV: Администрирование 0 28.12.2004 04:09
Navision Application Server Aleksander NAV: Администрирование 4 26.02.2004 02:28
Часовой пояс GMT +3, время: 20:29.
