#26 |
Вот кстати разбор от Docentric, интерестно конечно много вообще у них продаж своего модуля(цены на сайте почему-то нет)
https://ax.docentric.com/are-configu...5fo-reporting/ Цитата:
Pros
End-users can change business document designs including adding additional data from within D365FO, i.e. without deployments. Provides Business documents management, a setup for document templates with versioning. 34 core documents and 64 localized templates in Word and Excel are provided out-of-the box for most common business documents such as invoices and orders. Cons No PDF output. Very limited design capabilities with no preview option. Cannot be printed to printers. Partial Print Management integration: cannot configure different target print destinations for the same template. (Should provide) strong data fetching capabilities in terms of adding additional data. However, since Microsoft wanted to reuse the existing SSRS data provider classes, this solution actually seems to be even more complicated than SSRS, especially when it comes to debugging and solving data fetching likewise design issues. Business documents management (i.e. setup for templates) provides versioning, which is a good thing! Still, keeping all the templates for all possible reports on flat doesn’t seem as well organized template storage. Also, the process of adding new templates (by deriving from a configuration or creating a new one in a separate place – ER workspace) seems a bit complicated too. |
| За это сообщение автора поблагодарили: fed (2), Vadik (1). | |
