10.12.2017, 08:11 | #1 |
EDT and tables wizard for AX 2012
Источник: http://alexvoy.blogspot.com/2017/12/...r-ax-2012.html
============== [COLOR=rgba(0, 0, 0, 0.54)]AX 2012 Wizard allows to create new Extended data types and new tables with relations, delete actions, indexes and find methods, based on a simple Excel file. Two sample Excel files are included in the zip-package.[/COLOR] [COLOR=rgba(0, 0, 0, 0.54)] [/COLOR][COLOR=rgba(0, 0, 0, 0.54)]Just import two classes (ADO class is to support Excel import).[/COLOR] [COLOR=rgba(0, 0, 0, 0.54)] [/COLOR][COLOR=rgba(0, 0, 0, 0.54)]You can set up new types (if needed) and new tables with all bells and whistles, then run the Wizard and can go fishing until it does its job.[/COLOR] [COLOR=rgba(0, 0, 0, 0.54)] [/COLOR][COLOR=rgba(0, 0, 0, 0.54)]Happy fishing![/COLOR] [COLOR=rgba(0, 0, 0, 0.54)] [/COLOR] It creates: first - all new types based on basic types; (ignores if exists) - all new labels for US-EN and FR-CA or finds existing one for US-EN; second - new tables; - new fields; - new field group with all new fields and the same label as for table; - new index based on the first field and set is as cluster index; - normal relation to the main table if given (one only); - cascade delete action for all new relations from subordinated tables; - method find based on the first field. If it fails to open Excel file, check your currently installed Excel version and adapt the connection string. Источник: http://alexvoy.blogspot.com/2017/12/...r-ax-2012.html
