Старый 13.01.2017, 03:43   #1
skuull is offline
skuull
700 / 752 (27) +++++++
Если посмотерть в SysSetupForm.formControlMove там есть код
    // If control was already moved userOrgContainer is different from 0
    formControlUserOrgContainer = formControl.userOrgContainer();
даже с комментами, не оно?
formbuildcontrol, formcontrol, personalize
Restrict access to group form control in the grid Blog bot DAX Blogs 0 17.10.2016 23:11
stoneridgesoftware: Creating a Default Lookup Form with Filter in Dynamics AX Blog bot DAX Blogs 0 29.07.2016 02:37
dynamicsax-fico: Budget control for fixed assets – Part 1: AX2012 Blog bot DAX Blogs 0 16.04.2016 20:16
emeadaxsupport: Form created in e.g. AX 2012 RTM or AX 2012 R2 with ManagedHost control on its design fails to open on AX 2012 R3 Blog bot DAX Blogs 0 21.09.2015 19:11
emeadaxsupport: Users don't want to delete their usage data - but you've redeveloped the form - the solution Blog bot DAX Blogs 0 21.04.2011 22:11
Часовой пояс GMT +3, время: 14:29.
